does anyone know where the engine coolant drain bolt is on a d15b7?
Old Jul 31, 2007 | 03:01 PM
ehonda1980's Avatar
Default does anyone know where the engine coolant drain bolt is on a d15b7?
i thought i found it but was wrong. pictures would be appreciated. not the radiator drain plug but the bolt on the block.
Old Jul 31, 2007 | 03:06 PM
hatchling37's Avatar
Default Re: does anyone know where the engine coolant drain bolt is on a d15b7? (ehonda1980)
Follow the hose from your radiator to the water neck. On top of the neck is a banjo bolt. It looks similar to the ones on your calipers and on your clutch slave cylinder. It is facing directly upward. That is what you seek, child.
Old Jul 31, 2007 | 03:20 PM
ehonda1980's Avatar
isn't that the bleeder bolt?
Old Jul 31, 2007 | 04:49 PM
ehonda1980's Avatar
found it its that big bolt under the exhaust manifold
Old Aug 1, 2007 | 12:18 AM
Mista Bone's Avatar
D Tranny Guru
kaivorth
Honda Civic (2001 - 2005)
Oct 31, 2016 04:48 AM
marty17
Dec 13, 2009 06:55 PM
OogalyDoogaly
Honda Motorcycles
Feb 4, 2008 05:31 AM
dlszrfn
Mar 30, 2005 08:01 PM
blueeg
Jan 22, 2004 07:08 AM
