can you weld this???
Old Jul 31, 2007 | 12:28 PM
joey1320's Avatar
Default can you weld this???
as the title says i'm having a friend weld me a log manifold and i need to know if this parts are weldable??? thanks!
this
to this
Old Jul 31, 2007 | 12:35 PM
F20Cteg's Avatar
Default Re: can you weld this??? (joey1320)
Yes.
Seriously, look at the name of those two pipes in the lower right corner of each spec sheet.
It says " BUTT-WELD"
What's the reducer gonna be for?
Old Jul 31, 2007 | 12:36 PM
Mykizism's Avatar
not to sound like an *** but, at the bottom right corner of thoes pics.. it says butt weld..
Old Jul 31, 2007 | 12:52 PM
Mikey3000's Avatar
the ODs are different, it won't really be a butt weld. it looks like the 1.9" OD of the elbow will either fit inside the big end of the reducer, or outside the small end of the reducer.
Old Jul 31, 2007 | 01:33 PM
joey1320's Avatar
Default Re: can you weld this??? (Mikey3000)
thanks guys i was just asking because one is stainless steel and the other is just steel, didn't know if it was gonna be a problem.
this is the turbo that i'm using and the reducer is to connect the flange to the manifold. i just didn't wanna just use a straight 1.6" od pipe with a 1.3" id.
thanks again
Old Jul 31, 2007 | 02:41 PM
9bells's Avatar
OG Fabricator
Just make sure to use a 309L filler to weld it up, it's done all the time.
Old Jul 31, 2007 | 04:16 PM
joey1320's Avatar
Default Re: can you weld this??? (9bells)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9bells &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure to use a 309L filler to weld it up, it's done all the time.
thanks will make sure to get that done.
also will the steel reducer be ok for a turbo manifold???
Old Jul 31, 2007 | 09:02 PM
johnny5gti's Avatar
if im not mistaken. thats a VW ko3s turbo? why such a small turbo?
Old Aug 1, 2007 | 12:00 PM
joey1320's Avatar
Default Re: (johnny5gti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnny5gti &raquo;</TD></TR><TR><TD CLASS="quote">if im not mistaken. thats a VW ko3s turbo? why such a small turbo?</TD></TR></TABLE>
is actually a garrett gt2056 direct replacement for the k03. i got it for free after my friend paid $690 for it. he used it for 4k miles and went to a gt30!@#$%^&*.
plus is gonna go on a toyota yaris with a 1.5L engine at 7.5psi. (stock engine)
Old Aug 1, 2007 | 12:40 PM
ManBearPig4silly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joey1320 &raquo;</TD></TR><TR><TD CLASS="quote">thanks will make sure to get that done.
also will the steel reducer be ok for a turbo manifold???</TD></TR></TABLE>
Yeah most people use mild steel flanges. WHy the reducer anyway? I guess the only way it could be a problem is if it's welded inbetween two piece of stainless that are bolted to something or other. Different rates of thermal expansion can be a bitch sometimes.
Old Aug 1, 2007 | 05:47 PM
*Boostwerks*'s Avatar
Default Re: can you weld this??? (F20Cteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">
Yes.
What's the reducer gonna be for?</TD></TR></TABLE>
That just means it can be welded to your anus.
Old Aug 1, 2007 | 06:56 PM
joey1320's Avatar
Default Re: can you weld this??? (ManBearPig4silly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ManBearPig4silly &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah most people use mild steel flanges. WHy the reducer anyway? I guess the only way it could be a problem is if it's welded inbetween two piece of stainless that are bolted to something or other. Different rates of thermal expansion can be a bitch sometimes. </TD></TR></TABLE>
ok the plan for the reducer is to be used to connect the manifold to the turbo using a 3/8" ss flange.
i'll have to use abot 2" of tubing to properlly position the turbo and as you can see the turbine inlet is a funky design, so instead of using a 1.3" id ss tube i was gonna use the reducer(2"-1.3") to make the flow better.
i can't find the ss reducer for the size i need, so i may get the steel one, will it work?
Old Aug 2, 2007 | 02:02 PM
F20Cteg's Avatar
Default Re: can you weld this??? (Boostwerks.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com &raquo;</TD></TR><TR><TD CLASS="quote">
That just means it can be welded to your anus. </TD></TR></TABLE>
Ya, but what kind of filler would you have to use?
Old Aug 2, 2007 | 02:09 PM
93supercoupe's Avatar
that would be the #2 anus fudge filler.
Old Aug 2, 2007 | 04:48 PM
I'm pretty sure the shittiest steel possible will work.
aka...unweldable rebar.
Old Aug 2, 2007 | 06:29 PM
F20Cteg's Avatar
aka...unweldable rebar. </TD></TR></TABLE>
You have to use methane for the gas.
NAEGH22
Welding / Fabrication
Jun 22, 2010 09:52 PM
slow hatch
Sep 10, 2007 11:07 PM
b_ron007
27
Mar 10, 2006 08:01 PM
ORcivicsi
Aug 20, 2004 10:50 PM
Tire Monkey
Mar 9, 2004 02:14 PM
