Inaccurate Temp Guage
Old Jul 31, 2007 | 11:45 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Inaccurate Temp Guage
I recently replaced the water temp sensor (broke the lead off during tranny removal) and now my temp guage reads hot. When I first start the car, the needle moves to what used to be normal operating temp and then moves to about 7/8 of the way up the guage and stays there.
Is there anyway to reset/adjust this without removing the cluster? Will reseting the ECU take care of the problem?
Old Jul 31, 2007 | 03:48 PM
hondadude's Avatar
Default Re: Inaccurate Temp Guage (213374U)
temp gauge sending unit should read about 140 ohms with engine cool and approx 40 ohms engine fully warmed up [fans cycled]
You could also check that the wire going to the sender isn't grounded as that would also cause the gauge to mis-read.
Resetting the ECU will do no good
Old Jul 31, 2007 | 05:49 PM
phootbag's Avatar
sounds like you may have gotten the wrong sending unit. Like hondadude said, ohm it.
klinster
Sep 23, 2009 04:19 PM
zippakilla
Feb 21, 2009 11:02 AM
nz_mike
Aug 24, 2007 02:54 PM
Da1spaz247
Oct 12, 2005 02:33 PM
bigTom
Mar 5, 2002 04:48 PM
