1st time at the track... need some advice
Old Jun 11, 2002 | 12:20 AM
93HtchBk's Avatar
Default 1st time at the track... need some advice
I drive a 93dx hatch w/ a b16. I'm running basically a stock motor... just a short ram intake and a cheap exhaust w/ stock piping, also have 16inch rims w/ tire psi lowered to 30psi. I do have a new ACT clutch though. Heres my fastest timeslip.
R/T 1.203
60' 2.498
330 6.799
1/8 10.259
mph 71.45
1000 13.205
1/4 15.721
MPH 88.57
I ran twice and improved my R/T to .631 but still got a worse 1/4 time. I know i need to improve my 60ft time. I think i launched too low... i dumped it at about 3k rpm. I was expecting 15's but was hoping to get a little lower.
My final goal is to get into the mid 14's. Any advice on what I should invest in next? Should i get a good I/H/E setup or should i go for cams and possibly pistons? I want to avoid n2o.
Also, I have been debating to go either turbo or N/A... with my goal being mid 14's what route sounds best.
Old Jun 11, 2002 | 01:02 AM
gsrvx's Avatar
New User
Default Re: 1st time at the track... need some advice (93HtchBk)
I'm guessing palmdale?
Old Jun 11, 2002 | 05:13 AM
DevinW's Avatar
For mid 14s I think N/A would be a good choice. You might want to try a nice I/H/E setup along with setting your tires down to about 22-24 psi. (Start high and work low) That should get you into the low 15s at least...
Old Jun 11, 2002 | 06:51 AM
smeister's Avatar
You don't need to worry about your R/T since the timer starts once you launch. You should be able to do mid 14s with just NA.
Old Jun 11, 2002 | 11:29 AM
93HtchBk's Avatar
Default Re: 1st time at the track... need some advice (smeister)
I ran at California Speedway in Fontana. Was I launching too low?
EikoU
Nov 24, 2005 09:15 AM
B18C1CYA
Jul 26, 2004 03:26 PM
Rob!
75
Jul 8, 2004 05:49 PM
Evil EG
Jul 3, 2002 09:12 AM
UCLAsi
Feb 28, 2002 08:58 AM
