Car hesitates on Acceleration. Dont flame, Search is down.
Old Jul 31, 2007 | 10:22 AM
street_ride14's Avatar
Default Car hesitates on Acceleration. Dont flame, Search is down.
Search function is down and I know there are many topics on this one, but I need to know quick ...
Car hesitates during acceleration, doesn't want to accelerate freely, it feels like I'm towing a Semi behind me. Every gear.
Swapped Cylinder heads and the crank timing is off a Tooth. Cams are at TDC marks. I feel that my Distributor is also off, but not sure.
Car starts and drives, but hesitated to accelerate really Badly. Any input ??????
Under normal cirmunstances ... I would do a Search on this, but beleive me I have tried like 15 times and no luck. H-T servers are off on timing, someone tune this ****. Thanks.
Old Jul 31, 2007 | 10:33 AM
Finest's Avatar
Default Re: Car hesitates on Acceleration. Dont flame, Search is down. (street_ride14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">Swapped Cylinder heads and the crank timing is off a Tooth. Cams are at TDC marks. I feel that my Distributor is also off, but not sure.
If your crank timing is off a tooth, that's like being off 3-4 teeth on the camgears.
Re-time everything correctly and put it back together.
Old Jul 31, 2007 | 10:37 AM
Hawkze_2.3's Avatar
Swapped Cylinder heads and the crank timing is off a Tooth. </TD></TR></TABLE>
I can't believe you even tried to drive it like that.
Fix the timing.
Old Jul 31, 2007 | 12:48 PM
gogunkergorilla's Avatar
you can still search using google
Old Jul 31, 2007 | 02:24 PM
drummr6's Avatar
if fixing timing doesnt do it for ya then the dizzy may not be advancing correctly
290allen
12
Mar 23, 2012 07:34 PM
dcomer04
May 30, 2008 08:33 PM
1sikhatch
Feb 23, 2007 08:17 PM
hb_racer
Aug 10, 2002 07:49 AM
