acceleration problems
my 91 teg with a b18b intsalled still running obd0 runs great, until it warms up it seems like once i drive around for about 5 or 6 mins it doesnt accel. right. it kinda of lunges instead of a smooth take off, but if i take off wot or just a little less it doesnt do it. my tps has been replace due to being broke when i bought the motor so i originally thought that was it but that was a year ago and its been more noticable here lately, the list of mods include. cai, dc header and 2.5in exhaust to a can. and turbo next week i would like to resolve this before i put the turbo on it oh and i replaced o2 sensor plugs wires cap button and fuel filter and still nothing, plus im only getting 23mpg at the best and the motor has 81k on it
it idles around 700 to 1000 rpms, ive checked for vacuum leaks in the past, my car does idle rich like if it had a vacuum leak. and sometimes my brake pedal will go all the way to the floor, would that be because of a vac leak in the booster or my master cylinder going bad.
If it idles at a constant speed (either 700 or 1000 RPM), then there is not a vacuum leak. This would cause and erratic idle (surging).
The correct way to check for vacuum leaks is to use a vacuum gauge hooked up to the manifold while the engine idling. Once you know there is a leak, visual inspection of all seal points.
emmanuel2112 you can spray carb cleaner on vacuum line connections, tb and manifold and if theres a leak the car idle will stumble
ftrms
Apr 14, 2010 05:58 PM
Cameron60
Jun 6, 2007 08:12 AM
