1992 2.2 JDM VTEC - AA Man says snapped timing belt but sounds like chain
Old Jul 31, 2007 | 02:13 AM
polgster's Avatar
Default 1992 2.2 JDM VTEC - AA Man says snapped timing belt but sounds like chain
Was doing 30mph without VTEC engaged and car stopped. When I turn it over it sounds like a bag of spanners rattling around. Is it a timing chain or belt? If it's a chain then it could be the sound of the chain thrashing around.
What are my chances of not damaging any valves etc? The car's quite old and may not be worth repairing.
Any help would be appreciated
Old Jul 31, 2007 | 02:23 AM
98vtec's Avatar
moderator emeritus
Default Re: 1992 2.2 JDM VTEC - AA Man says snapped timing belt but sounds like chain (polgster)
we have belts
Old Jul 31, 2007 | 03:31 AM
PirateMcFred's Avatar
If you did not break the belt whist in VTEC then you should not have bent valves. It's a free running (non interferance) engine when on the low cam lobes.
If you do repair the belt you should upgrade to the F22/H23 nonVETC manual timing tensioner. The autotensioners have a reputation of failing prematurely.
Sorry for your misfortune.
Old Jul 31, 2007 | 03:42 AM
polgster's Avatar
Default Re: 1992 2.2 JDM VTEC - AA Man says snapped timing belt but sounds like chain (PirateMcFred)
Thanks for that, it gives me hope as I've had conflicting replies in other forums.
Can you explain what the metalic sound would be when I try to start the car? I thought it may have been a chain but if it's a belt then what's making the noise?
Old Jul 31, 2007 | 03:46 AM
98vtec's Avatar
moderator emeritus
could be alot of things. Run a leakdown test and determine what the health of the inside is.
Old Jul 31, 2007 | 04:15 AM
carnot's Avatar
do you guys know if a stock H23 is a free running non interface engine?
Old Jul 31, 2007 | 04:52 AM
Default Re: 1992 2.2 JDM VTEC - AA Man says snapped timing belt but sounds like chain (carnot)
I used to remember. I want to say that it's an interference engine but I can't remember. The stock H22 low cam lobes are less than .300" lift and the peak lift on an H23 is close to .375". That's a pretty big difference. And the h23 does not have very large valve reliefs in the pisotns either. I have some pretty large cams on my nonVTEC F22B now. I know that it's got a lot of interference after that. I had my timing belt slip once already. Replaced a lot of valves. It was of the not good.
If you have an H22 then you don't ahve to worry about it.
Old Jul 31, 2007 | 05:35 AM
.BigSexy's Avatar
most hood white kid
lol, h22's don't have chains
Old Jul 31, 2007 | 06:04 AM
v4lu3s's Avatar
RTFM
while coasting down in gear at about 40 mph i had a timing belt snap, and i bent every exhaust valve. I did have type-s pistons at the time though.
Old Jul 31, 2007 | 06:20 AM
h22a1_julien's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">while coasting down in gear at about 40 mph i had a timing belt snap, and i bent every exhaust valve. I did have type-s pistons at the time though.</TD></TR></TABLE>
that must have costed you alot..lol
Old Jul 31, 2007 | 06:21 AM
On stock cams? My buddy here had his auto tensioner fail 100 miles from home and his valves are fine. Good compression, everything. He's been driving it for a while now after replacing the belt and upgrading to the manual tensioner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .BigSexy &raquo;</TD></TR><TR><TD CLASS="quote">lol, h22's don't have chains</TD></TR></TABLE>
Yeah, we've established that.
Old Jul 31, 2007 | 06:28 AM
preludestud11's Avatar
Default Re: (PirateMcFred)
LOl, i was driving in 3rd gear at 30 mph Like 2,000 rpm, and had the key break the crank, and it ben 13 out of the 16 valves.
Old Jul 31, 2007 | 06:33 AM
polgster's Avatar
Default H22
Gunna go home and check that the engine codes match upto a H22 and will drop it into the garage and take my chances. Still not sure what the noise is when I turn it over though.
Old Jul 31, 2007 | 06:45 AM
Default Re: H22 (polgster)
Replace the timing belt real quick and do a compression test. If you have no compression then you probably have bent valves.
Old Jul 31, 2007 | 07:32 AM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, we've established that. </TD></TR></TABLE>
sorry, I read the first post and hit reply...shame on me::sarcasm::
Old Aug 23, 2007 | 08:44 PM
placid888's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carnot &raquo;</TD></TR><TR><TD CLASS="quote">do you guys know if a stock H23 is a free running non interface engine?</TD></TR></TABLE>
YES, H23 is an interference engine, i saw 2 H23 bent valves when timing belt ripped
Old Sep 11, 2007 | 06:12 AM
polgster's Avatar
Default Re: 1992 2.2 JDM VTEC - AA Man says snapped timing belt but sounds like chain (placid888)
OK finally got to throw my car in and get it checked, luckily they were able to see the damage with the head off so only cost me £20.
THE H22A IS AN INTERFERENCE ENGINE
Mine was a 1992 jdm 2.2 si vtec
Hope this helps someone
Old Sep 11, 2007 | 08:17 AM
That sucks. I hope you can get it fixed for a reasonable amount of money.
Old Sep 12, 2007 | 02:28 AM
polgster's Avatar
Default Every cloud has a silver lining
Managed to pickup same spec car with a full veilside bodykit and smoothed boot for £500. It's a bit tatty and the kit hasn't been fixed properly but hey what a bargain and I can use my old one for spares.
Old Sep 12, 2007 | 08:10 AM
mgags7's Avatar
it may be that US h22s are non-interference and jdm ones are. the pistons are slightly different.
The grinding noise is the sound the autotensioner makes when it fails and the belt puts pressure on it.
Psycho719
Sep 14, 2011 04:28 AM
erok515
Jul 29, 2008 04:22 AM
duceducecord
Feb 26, 2006 08:31 AM
jsnm
Aug 29, 2005 09:44 AM
rybred
Dec 7, 2002 09:58 PM
