New Prelude
Well while on my way to check for leaks in my a/c in my 92 prelude, my step dad calls me and tells me about a 1994 prelude si, for sale. to make a long story short, im the proud new owner of the si. But the cars got some problems maybe yall can help me determine whats wrong. For one the power steering squeels really bad, also the car burns oil, and throws smoke out the exhaust. what do you think the problem is? does it need a valve job or .....???? not sure. But other than that its cherry and 100% stock. Im switching my volks, mugen wing, and steering wheel over and my azect eyebrows to the new car as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by giddyup21 »</TD></TR><TR><TD CLASS="quote">check power steering fluid and belt tension.
also, what color is the smoke coming out of your exhaust?</TD></TR></TABLE>
To be honest i didnt see the smoke for myself, but i believe it was black
well no, i havnt even picked up the car yet, its at the bodyshop. but the previous owner said they had to add oil every 2-3 weeks, that it burns it, no leaks on the floor. My friend said it could be the piston rings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ninja »</TD></TR><TR><TD CLASS="quote">well no, i havnt even picked up the car yet, its at the bodyshop. but the previous owner said they had to add oil every 2-3 weeks, that it burns it, no leaks on the floor. My friend said it could be the piston rings</TD></TR></TABLE>
do a leakdown test ...that should give you a good idea of what is faulty...
power steering pump could be the problem with the squeeling. Just listen to the power steering pump with motor running using a doller store stethoscope. If you hear grinding its f*ked.
Also, smell and look at the ps pump oil from the resivoir. If its blackened/dirty/impure than thats another indication that things are bad in that system.
professorman
Feb 13, 2007 10:31 AM
