b16 swap/at to mt
Old Jul 30, 2007 | 08:31 PM
john256's Avatar
Default b16 swap/at to mt
Like the title says, I want to swap my d16z6 block and d16 non vtec head to a b16.. Also while i'm at it swapt the tranny to manual. I found a complete swap motor,axles,shift linkage, tranny ecu, wiring harness, starter, and problem the slave.
So, all i would need is the master, and the shifter itself? + wirin the reverse light.
Old Jul 30, 2007 | 08:39 PM
94hondacivicvtec's Avatar
Default Re: b16 swap/at to mt (john256)
you will also need the conversion mount(s) depending on what car you have.
Old Jul 31, 2007 | 09:30 AM
john256's Avatar
its the sir II swap to a 93 civic sedan. So the motors stock mounts will work?
Old Jul 31, 2007 | 10:53 AM
philosofy1's Avatar
Default Re: (john256)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john256 &raquo;</TD></TR><TR><TD CLASS="quote">its the sir II swap to a 93 civic sedan. So the motors stock mounts will work?</TD></TR></TABLE>
if the motor does not come with it you will need the t-bracket for the rear mount and you will need the conversion moutn for the tranny. the tranny brackets sit higher on the autos than the manuals.
as for finishing the swap, you will need:
1. the clutch line
2. clutch master cylinder
3. clutch fluid resevoir
4. resevoir bracket
5. clutch pedal
6. brake pedal (auto brakes are wider than manuals, so it will interfer w/ clutch pedal)
7. rubber clutch line ( i forgot the exact name to it, but it's the one that runs from the hard line to the slave cylinder.
and if i'm forgeting anything H-T help me out!
reggiemurphysi
Transmission & Drivetrain
Mar 10, 2015 02:29 PM
EK_kidd
Apr 11, 2008 08:02 AM
Tuesdaynightfever
Apr 3, 2005 12:32 PM
PDXHatchback
13
May 30, 2004 06:45 PM
gribbs
Aug 26, 2003 09:06 PM
