code 20 (electronic load detector) on 91 integra converted to obd1. HELP!!!!
Old Jul 30, 2007 | 08:27 PM
danb18c's Avatar
Default code 20 (electronic load detector) on 91 integra converted to obd1. HELP!!!!
I have a 91 integra gs with a 95 gsr motor. Recently I converted it to obd1. I bought the conversion harness, running a P72 ecu, got a 95 gsr dizzy, converted the plugs ,and got a 4 wire obd1 o2 sensor. Everything is fine except now im throwing a code 20 (electronic load detector) and can’t figure out why. Some one told me to replace the under hood fuse box, so I did and still throwin the code! Is there something special I have to do for the conversion??? Or is something just wrong?!? Someone HELP!
Old Aug 7, 2007 | 09:10 PM
danb18c's Avatar
Default Re: code 20 (electronic load detector) on 91 integra converted to obd1. HELP!!!! (danb18c)
bump anyone?????!!!!
Old Aug 10, 2007 | 10:10 AM
Ls92's Avatar
Default Re: code 20 (danb18c)
I have a pr4 ecu and then i got it chipped (using crome).I've had that code since then .I called the dealership and they have no idea what the ELD is but from what I hear it dosent cause a problem.My car has been running with it since Nov 06
Old Aug 10, 2007 | 10:15 AM
EdoMoto's Avatar
Its a problem with your computer the 90-93 integras dont have any ELD. Disable it within the ECU.
Edo
Old Aug 10, 2007 | 11:00 AM
MoonScryer's Avatar
Default Re: code 20 (EdoMoto)
You need to get a custom chip for your p72. The DA's don't have an ELD.
h22integra.eire
Engine Management and Tuning
Sep 14, 2015 06:08 PM
Slo_jspec
Apr 11, 2010 12:19 PM
skunkiemonkeynutz
Mar 4, 2008 03:51 AM
EkHatch13
Oct 24, 2002 12:04 PM
