running rich!!!
got a 94 civic ex d16z6, any way im running really rich. just replaced the o2 sensor, changed fuel filter, and reset the ecu but nada. what else is there to check or replace? any help appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by curtisb16 »</TD></TR><TR><TD CLASS="quote">it sounds like youre ecu is malfunctioning you need to replace and see if that dose the trick. if not need to check injectors and see if damaged. </TD></TR></TABLE>
Stock ECU malfunction? That doesn't happen.
To the OP, how do you know you are running rich?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg »</TD></TR><TR><TD CLASS="quote">
yeah its a stock p28 virgin, never been opened or messed with. I have a little black smoke on top of black spot on bumper with a bad smell of gas coming out the exhaust (sniffed the exhaust wile running). I've never replace the injectors, fuel pump, fuel regulator, tps, map, iacv. is there any thing else it could be? i put in some iridium's 3 months ago my friend gave me. would that do it?
my car was running rich code 45 and everything....turns out my plug wires were bad....replaced those then I got a code for the primary o2 sensor....replaced that now I have my fingers crossed...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PYITR821 »</TD></TR><TR><TD CLASS="quote">my car was running rich code 45 and everything....turns out my plug wires were bad....replaced those then I got a code for the primary o2 sensor....replaced that now I have my fingers crossed... </TD></TR></TABLE>
good luck man i hope that fixes your problem, i replaced the map with one i had laying around. i don't see any black smoke but i can still smell gas alittle bit, what else could it be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec »</TD></TR><TR><TD CLASS="quote">all right will do, getting about 225 per tank any thing else open to any ideas</TD></TR></TABLE>
Keep in mind that gas mileage is largley affected by driving habits. Agressive driving behavior will suck up gas fast.
ncdos
Aug 5, 2006 12:18 PM
allicedout
Jul 2, 2004 05:07 PM
