Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Valve clearance adjustment
Old Jul 30, 2007 | 07:19 PM
petty$rep's Avatar
Default Valve clearance adjustment
Hey guys,
I searched multiple times to find an old write up on how to do a valve clearance adjustment on the D17 motor, but i could not find the thread. So if someone could please post it up that will help a lot. I also searched the FAQ page but it was not there either.
Thanks guys
Old Jul 30, 2007 | 07:29 PM
petty$rep's Avatar
Default Re: Valve clearance adjustment (petty$rep)
Is search working for anyone else at the moment, or is there something currently wrong with the search feature???
Old Jul 30, 2007 | 07:56 PM
Boilermaker1's Avatar
remove valve cover, rotate each cylinder to TDC, adjust Intake valves .008-.010, adjust exhaust valves .009-.011.
Old Jul 30, 2007 | 08:39 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petty$rep &raquo;</TD></TR><TR><TD CLASS="quote">Is search working for anyone else at the moment, or is there something currently wrong with the search feature???</TD></TR></TABLE>
There was a huge server patch performed yesterday. It's been rather slow getting all of the functionality back for the site.
Old Jul 30, 2007 | 08:47 PM
EM2ner's Avatar
Default Re: Valve clearance adjustment (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
There was a huge server patch performed yesterday. It's been rather slow getting all of the functionality back for the site.</TD></TR></TABLE>
That's what was wrong. I thought it was my internet cause my bookmark didn't work for this site lol...
Old Jul 31, 2007 | 07:14 AM
petty$rep's Avatar
Default Re: Valve clearance adjustment (EM2ner)
thanks guys, i will try searching again now that it's working.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">remove valve cover, rotate each cylinder to TDC, adjust Intake valves .008-.010, adjust exhaust valves .009-.011.</TD></TR></TABLE>
i know how to do it, i just cant figure out how to get all of the wires off the top of the valve cover . Its probably something easy, but i was just tired and didn't feel like workin on it.
Old Jul 31, 2007 | 06:37 PM
phootbag's Avatar
These are a bitch if you haven't done them. I did a Tbelt/Waterpump on one today in 1.5 hours. But, I've done about 100 of them...
Just take your time and pay attention. It isn't nearly as bad as it looks. I like to use bungee cords to hold everything out of my way while I'm working. Helps to keep from chopping the valve cover gasket when reinstalling it. That is the biggest problem I see people having when doing these. Good luck.
Old Jul 31, 2007 | 06:40 PM
petty$rep's Avatar
Default Re: (phootbag)
search still is not working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phootbag &raquo;</TD></TR><TR><TD CLASS="quote">These are a bitch if you haven't done them. I did a Tbelt/Waterpump on one today in 1.5 hours. But, I've done about 100 of them...
Just take your time and pay attention. It isn't nearly as bad as it looks. I like to use bungee cords to hold everything out of my way while I'm working. Helps to keep from chopping the valve cover gasket when reinstalling it. That is the biggest problem I see people having when doing these. Good luck. </TD></TR></TABLE>
yeah, my only problem is getting all of the wires off the top of the valve cover in order to take it off. i unplug everything i could, but i was tired so i will go look at it again when i have a chance.
why couldn't they just make the d17 like the old d series??
Old Jul 31, 2007 | 06:44 PM
phootbag's Avatar
Default Re: (petty$rep)
To get the slack you need you have to remove the small bracket securing the AC line to the power steering bracket. Slip the harness through the opening and you're golden.
Old Jul 31, 2007 | 06:45 PM
petty$rep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phootbag &raquo;</TD></TR><TR><TD CLASS="quote">To get the slack you need you have to remove the small bracket securing the AC line to the power steering bracket. Slip the harness through the opening and you're golden. </TD></TR></TABLE>
thank you
Gomdohree
Jun 2, 2008 05:53 PM
bubbleboy22
Jul 19, 2007 08:21 PM
nonvtec92
Mar 17, 2007 07:33 AM
SkRiBLaH
Apr 11, 2005 01:20 PM
ECKSbloodECKS
Jul 11, 2004 09:31 PM
