popping
Old Jul 30, 2007 | 06:13 PM
haroldthefly91crx's Avatar
Default popping
in my 90 hf when i let out the any ideas as to what could be causing this?clutch when im in gear and when i press the brakes
Old Jul 30, 2007 | 06:24 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: popping (haroldthefly91crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haroldthefly91crx &raquo;</TD></TR><TR><TD CLASS="quote">in my 90 hf when i let out the any ideas as to what could be causing this?clutch when im in gear and when i press the brakes</TD></TR></TABLE>
Might be a bad motor or trans mount. Is there any play in the steering wheel?
Old Jul 30, 2007 | 08:47 PM
slow_rex_will's Avatar
Default Re: popping (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
Might be a bad motor or trans mount. </TD></TR></TABLE>
Old Jul 30, 2007 | 09:34 PM
garageEF's Avatar
Default Re: popping (slow_rex_will)
+1 for the motor mounts.....
Old Jul 30, 2007 | 09:36 PM
innes887's Avatar
i have the same problem. i check the motor mounts for loose bolts but all were tight. i prob just broke one
Old Jul 31, 2007 | 07:15 PM
Default Re: (innes887)
i checked all the mounts they are fine
Old Jul 31, 2007 | 07:21 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (haroldthefly91crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haroldthefly91crx &raquo;</TD></TR><TR><TD CLASS="quote">i checked all the mounts they are fine</TD></TR></TABLE>
Just a visual inspection or did you actually pry at them / move the engine and trans to see if they're not sound?
Old Aug 1, 2007 | 05:49 AM
mahatma's Avatar
radius rods?
Old Aug 1, 2007 | 12:38 PM
innes887's Avatar
well i just rechecked my mounts and i ripped 2 do you think if i put the energy suspension mount inserts in them that it would cure it?
Old Aug 1, 2007 | 12:54 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by innes887 &raquo;</TD></TR><TR><TD CLASS="quote">well i just rechecked my mounts and i ripped 2 do you think if i put the energy suspension mount inserts in them that it would cure it?</TD></TR></TABLE>
I knew it. You can try to do the inserts as long as it's only the rubber portion that's damaged.
Old Aug 1, 2007 | 02:41 PM
Default Re: (wiZCo)
i lifter the car on a lift and took the mounts apart and they were ok but it may be the radious rods, ill check when i ger a chance
Old Aug 1, 2007 | 10:53 PM
innes887's Avatar
i tried finding the inserts at a a bunch of auto parts stores but none of them had it. i remember reading before that someone put some sort of caulk inside of the mount it self to make them more solid. does anyone know the caulk used?
Old Aug 2, 2007 | 06:37 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by innes887 &raquo;</TD></TR><TR><TD CLASS="quote">i tried finding the inserts at a a bunch of auto parts stores but none of them had it. i remember reading before that someone put some sort of caulk inside of the mount it self to make them more solid. does anyone know the caulk used?</TD></TR></TABLE>
It was 3M window sealant.
globy123
Nov 25, 2007 07:43 PM
tomlinson619
Feb 18, 2006 12:07 PM
HondaNerd
Jun 20, 2005 07:40 PM
buttzino
Aug 31, 2004 07:00 AM
kenethcole411
May 14, 2003 12:05 PM
