Axle Install
Old Jul 30, 2007 | 06:04 PM
SR20S13's Avatar
Default Axle Install
so i just replace my LX tranny with one from an Si, but now i cant seem to install the axles back in, there just not going all the way in and bottoming out like helms tells me to? I just dont get why?
Old Jul 30, 2007 | 06:07 PM
forcefedferio's Avatar
Default Re: Axle Install (SR20S13)
try wiggling the inboard joint with your hand...if that doesnt work hold the axle straight and hit the end with a RUBBER hammer this helps the clip pop into place.
Old Jul 30, 2007 | 06:11 PM
97Ej6mike's Avatar
rubber hammer or a sideways hammer on the axle can help force it in. Axles arent going to go in easy, so dont go easy on them, some manhandling is required to get them in, just dont hit them too hard.
Old Jul 30, 2007 | 06:24 PM
SR20S13's Avatar
the driveshafts are still installed into the hubs, should i remove them from the hub?
Old Jul 30, 2007 | 06:26 PM
Default Re: (SR20S13)
probably would make it alot easier, they are just a 32mm nut away haha
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SR20S13 &raquo;</TD></TR><TR><TD CLASS="quote">the driveshafts are still installed into the hubs, should i remove them from the hub?</TD></TR></TABLE>
try it, it might help. Is anybody helping you? having help is always the key.
Old Jul 30, 2007 | 06:31 PM
SR20S13's Avatar
yea my dad is helping me, and were banging the **** out of it and still not going in, is there anyway that the former owner when he removed the driveshafts some how removed the clips to, becuase its about a 1/4 inch from sitting flush and still not moving
Old Jul 30, 2007 | 06:38 PM
instrument's Avatar
theres a ring in a groove at the end of the axle, if they've been removed a lot that can get a little too much play in it, i've had luck removing it, and pinching it a bit.
sledge hammers are good too...
Old Jul 30, 2007 | 06:40 PM
SR20S13's Avatar
yea its just wont go in like its bottoming out waybefore and no matter how hard we hit the ****** it just wont budge a milimeter
Old Jul 30, 2007 | 06:58 PM
SR20S13's Avatar
yea tryed to hit it even harder neither side will go in and we dont get why
Old Jul 30, 2007 | 07:01 PM
bmoua's Avatar
you replaced them with D-series Si axles right? just making sure...
Old Jul 30, 2007 | 07:05 PM
SR20S13's Avatar
Default Re: (bmoua)
no i thought that all d-series axles are the same
Old Jul 30, 2007 | 07:10 PM
smileycvc's Avatar
wait when you say si tranny what motor do you mean? D16 or B16?
Old Jul 30, 2007 | 07:20 PM
SR20S13's Avatar
Default Re: (smileycvc)
i'm not an idiot of course i mean D16 its an 1994 Civic LX
Old Jul 30, 2007 | 08:43 PM
SR20S13's Avatar
anyone?
Old Jul 30, 2007 | 09:54 PM
marksae's Avatar
You sure you got the axle lined up before you started hammering on it? Try rotating the axle while trying to push it in.
braass91
13
Jun 20, 2010 09:54 PM
thisguyhere
Honda Civic (2001 - 2005)
Nov 7, 2009 10:01 PM
kefka
Jul 16, 2004 03:34 PM
tecnic1
Jul 11, 2003 07:23 PM
Smashback
Mar 12, 2002 10:57 AM
