CF4 SiR-T F20B Questions!!
Old Jul 30, 2007 | 05:18 PM
FutureCivic's Avatar
Default CF4 SiR-T F20B Questions!!
Hey guys,
My good friend owns a 1999 SiR-T, he previously damaged his original motor and had it rebuilt by some shop.
Well....looks like the crank is making some noise, we suspect they used the crank out of the previous 'damaged' motor.
Long story short the shop did a bum job.
1. Does anyone know or have or can find the CORRECT engine bolt torque specs and clearances for the F20B?
2. Does anyone know where you can purchase aftermarket bearings and rings. (Will H22 bottom end stuff work?)
3. Will an H22 knock sensor work on the F20B?
4. Where can I get a complete gasket set? Or just Top or Bottom gaskets?
5. Will H22 adj. cam gears work on the F20B?
I think thats all the questions he has for now.
Thanks guys!
Old Jul 31, 2007 | 08:16 AM
oem_certified_accord's Avatar
Default Re: CF4 SiR-T F20B Questions!! (FutureCivic)
i'll just tell you for the rest of them...use the search button.
https://honda-tech.com/zerothread?id=1984632
maybe that'll help tho
michaelprice83
Feb 16, 2009 09:27 AM
fleetunner
Apr 2, 2006 06:59 PM
coryg79
Nov 11, 2004 03:30 PM
