b16a y1 speed singal
Old Jul 30, 2007 | 03:15 PM
fiji_crx's Avatar
Default b16a y1 speed signal wire
can sum1 plz let me know if the speed signal wire goes to the ecu then the gauge , or direct from gear box to gauge.
thanks
Modified by fiji_crx at 4:46 PM 7/30/2007
Old Jul 30, 2007 | 05:03 PM
Super Chicken's Avatar
Default Re: b16a y1 speed signal wire (fiji_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiji_crx &raquo;</TD></TR><TR><TD CLASS="quote">can sum1 plz let me know if the speed signal wire goes to the ecu then the gauge , or direct from gear box to gauge.
thanks
OK if I understand your gibberish correctly then I think you need to tell us whether you have an electronic speed sending unit on the tranny or not.
If you do then the wire goes from the speed sender to the ECU if not then you have a wire coming from the back of the speedometer to the ECU
Old Jul 30, 2007 | 05:52 PM
fiji_crx's Avatar
Default Re: b16a y1 speed signal wire (Super Chicken)
oooo forgot i have a 1990 b16a ef9..
Old Jul 30, 2007 | 10:49 PM
fiji_crx's Avatar
so any1?
Old Jul 31, 2007 | 12:08 AM
Mista Bone's Avatar
D Tranny Guru
answer chicken's question........
Old Jul 31, 2007 | 12:21 AM
fiji_crx's Avatar
Default Re: (Mista Bone)
as far as i know all b16a has electronic speed signal . zc d15 have cable,so how will i be able to find out which is the speed signal in ecu.
Old Jul 31, 2007 | 12:22 AM
Ak_ef9's Avatar
Default Re: (fiji_crx)
Plug B 16
Old Jul 31, 2007 | 12:26 AM
fiji_crx's Avatar
Default Re: (Ak_ef9)
het sorry man , but the search section comes as an error. anyways 16. wat is that,
Old Jul 31, 2007 | 12:34 AM
Ak_ef9's Avatar
Plug b is the middle one. and 16 is the vss signal.
I will try and get a wiring diagram
Old Jul 31, 2007 | 12:41 AM
fiji_crx's Avatar
thanks man , will wait
Old Jul 31, 2007 | 01:07 AM
Ak_ef9's Avatar
https://honda-tech.com/zero...age=1
Old Jul 31, 2007 | 01:48 AM
fiji_crx's Avatar
thanks man but since iam in fiji islands i have a japan model civic ef9 1990 b16a, any write for that or any pic
Zewle
Aug 8, 2007 07:09 PM
fiji_crx
Jul 31, 2007 12:22 AM
jakscivic
12
May 27, 2007 06:51 AM
yellowjdmcrx
Nov 22, 2005 08:05 AM
