bad ecu?
Old Jul 30, 2007 | 02:30 PM
Mr.Meowsome's Avatar
Default bad ecu?
**at the time of this post, the search feature was unavailable**
so i have an 89 hatch with an obd0 b16, pr3 ecu . its been throwing code 23 since the get go (knock), but it ran fine. about a week ago i started it up and it went into limp mode right away. i checked the CEL and it stayed lit like a light bulb. i thought it might be the ecu so i unplugged it for about a half hour. plugged it back in and ran fine. then a couple days later, same problem. this time i just shut it off and started it back up and it was fine. i tryed another pr3 and got the same results
what could be the problem?
dizzy?
ecu?
what are the causes and effects of a bad ecu?
Old Jul 30, 2007 | 07:45 PM
Default Re: bad ecu? (Mr.Meowsome)
Old Jul 31, 2007 | 02:57 PM
bump
Old Jul 31, 2007 | 02:59 PM
90Zcrx's Avatar
creak it open, look for leaking capacitors or anything that looks off.
Old Jul 31, 2007 | 04:15 PM
white90rexsi's Avatar
If it is doing the same thing with another ecu then your ecu is not bad. Depending on what goes bad, the light on the ecu will not light up at all. Have you checked your knock sensor and the wire from your knock sensor to the ecu?
Old Aug 1, 2007 | 10:36 AM
Default Re: bad ecu? (white90rexsi)
i havent checked the wire, but since i know **** about wiring i had a shop do that when i swapped it. i assume they double checked everything and they told me i had a bad sensor. but what does it mean when the CEL stays lit?
Old Aug 1, 2007 | 10:59 AM
90Zcrx's Avatar
if the CEL is solid it's sometimes a bad ground in the system. Often times this is the battery. It can be a pain in the *** to diagnose.
Old Aug 1, 2007 | 04:14 PM
Default Re: bad ecu? (90Zcrx)
well that makes sense, cause my positive terminal wont stay tight on the battery. i have the wrench in hand right now to go tighten it some more
anything else?
gtowni3
Sep 30, 2004 07:23 PM
TRhatchCRAP
Aug 27, 2003 07:01 AM
crxtreme27
Jul 1, 2003 04:30 PM
kim_2_da_chee
May 30, 2003 06:18 PM
kahren
Mar 8, 2002 01:54 PM
