intercooler fins
Old Jul 30, 2007 | 02:01 PM
TURBODC4TEG's Avatar
Default intercooler fins
what are you guys using to straighten the bent fins on your intercooler? tried searching but its not working. i also tried a small screw driver but it doesn't work to well
Old Jul 30, 2007 | 02:13 PM
thewrai6th's Avatar
Default Re: intercooler fins (TURBODC4TEG)
flat tip xacto blade
Old Jul 30, 2007 | 02:31 PM
Default Re: intercooler fins (thewrai6th)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th &raquo;</TD></TR><TR><TD CLASS="quote">flat tip xacto blade</TD></TR></TABLE>
anything else i could use that would be laying around the house?
Old Jul 30, 2007 | 03:15 PM
Kyle R's Avatar
I use very fine needle nose plyers.
Old Jul 30, 2007 | 04:44 PM
ProPerformance's Avatar
When we restore old cars at the shop we go to the local drug store and get a lice comb for the radiator..
Old Jul 30, 2007 | 04:52 PM
Kyle R's Avatar
Default Re: (ProPerformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProPerformance &raquo;</TD></TR><TR><TD CLASS="quote">When we restore old cars at the shop we go to the local drug store and get a lice comb for the radiator..</TD></TR></TABLE>
Innovative
Old Jul 30, 2007 | 09:56 PM
!moops vs moors!'s Avatar
Default Re: (herecomesboost)
straight blade screwdriver used carefully
Old Jul 31, 2007 | 02:41 AM
Default Re: (!moops vs moors!)
thanks everyone for your help, i tried to go to advance and get a radiator comb and they didn't have it so i'll figure something out with your tips
Old Jul 31, 2007 | 03:53 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (TURBODC4TEG)
i use 2 old airsaw blades.
Old Jul 31, 2007 | 08:11 AM
da_dude's Avatar
Just flip the IC around.
Old Jul 31, 2007 | 09:58 AM
Sprockets's Avatar
These are the pliers I use. Nice and small so you can also pick out rocks and bugs. Most needle nose pliers are serrated on the inside, but these are smooth.
Old Jul 31, 2007 | 10:22 AM
thewrai6th's Avatar
Default Re: intercooler fins (Sprockets)
I have those exact pliers, but they are too big for the fins on a high density IC. They might work for a radiator or cheap IC.
Old Jul 31, 2007 | 11:01 AM
Sprockets's Avatar
I've only used them on my Greddy Type 31, which back in the day cost me $675. Not exactly cheap. I'm not saying you can reach all the way inside, but the tip is perfect for flattening out bent fins. Radiators are higher density, by the way.
Old Jul 31, 2007 | 11:38 AM
thewrai6th's Avatar
Didn't mean to call your IC cheap I had the same IC.
I just had no luck with those pliers. They might work ok if the fins are really bent up.
I was looking at my cat's brush just now... might work good for cleaning.
Old Jul 31, 2007 | 12:24 PM
SovXietday's Avatar
My radiator has lice...
Old Jul 31, 2007 | 02:12 PM
AaronJ's Avatar
use a tweasers
Old Jul 31, 2007 | 02:50 PM
redtop91's Avatar
Default Re: (AaronJ)
Use your fingers... Pretty much anything will work. I always straighten mine by hand. The center part of the fin shouldn't be bent but if it is a small nail file will work LOL.
Old Jul 31, 2007 | 03:09 PM
Kyle R's Avatar
Default Re: (redtop91)
My plyers are similars to those pictured above, but mine are a little smaller.
Old Jul 31, 2007 | 05:09 PM
Sprockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th &raquo;</TD></TR><TR><TD CLASS="quote">Didn't mean to call your IC cheap </TD></TR></TABLE>
It's cool, lol. It's probably not worth much anymore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost &raquo;</TD></TR><TR><TD CLASS="quote">My plyers are similars to those pictured above, but mine are a little smaller. </TD></TR></TABLE>
I'm starting to wonder if I posted a pic of the wrong pliers. The ones I have came in a foam padded vinyl zipped pouch along with other types of small pliers. Anyway, the color is the same. I've also seen them in red and black.
Old Jul 31, 2007 | 05:17 PM
Kyle R's Avatar
Tube and Fin
Old Jul 31, 2007 | 08:59 PM
Sprockets's Avatar
Default Re: intercooler fins (herecomesboost)
Nah, not for me. Tube and fin is better for a daily driven car. Call me crazy, but I kind of like more air reaching my radiator. Bar and plate cools better, but it's more of a drag racing intercooler. I just got a 24x11x3 PWR that should be more than enough for my limited goals. I'm pretty sure that all the intercoolers that Full Rape uses are PWR tube and fin.
Old Jul 31, 2007 | 09:12 PM
Kyle R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets &raquo;</TD></TR><TR><TD CLASS="quote"> I'm pretty sure that all the intercoolers that Full Rape uses are PWR tube and fin.</TD></TR></TABLE>
Old Jul 31, 2007 | 09:24 PM
JaredKaragen's Avatar
Flip it over... lol, exactly what I did with the jetta IC =P
Old Aug 1, 2007 | 06:12 AM
twkdCD595's Avatar
Default Re: (JaredKaragen)
jewelers screwdriver and patience. if the fins are really mashed... I would try the tip of a razor blade to get under the edge then use the screwdriver to straighten it.
chadalac1712
38
Dec 14, 2006 12:35 PM
turbotime
Nov 16, 2006 10:30 PM
huge230
Welding / Fabrication
18
May 6, 2006 11:29 PM
P_t0wn
24
Oct 29, 2004 08:08 PM
Soon_2b_evil
Dec 11, 2003 01:01 PM
