Noob Turbo Question
Old Jul 30, 2007 | 12:47 PM
smileycvc's Avatar
Default Noob Turbo Question
Ok I have a question about the whole turbo thing. I dont know much about turbos, I kind of have an idea about how they work and everything, but I still dont understand one thing. So if you have 2 cars same turbo manifold everything. Same amount of boost, intercooler and piping.
Now if both motors are running 8 lbs of boost and one has a ported head and the other is stock which will make more power? I think the motor with the ported head will make more power since it can flow better. However now thats it ported how does the boost pressure stay the same?
Also if you had a diffrent turbo same size, but it flows more cfm it will make more power, but the boost is still the same. How does that work.
Old Jul 30, 2007 | 02:40 PM
integraRS-T's Avatar
Default Re: Noob Turbo Question (smileycvc)
if an engine is bigger,better shape it will be faster,on some turbos u need :example dont judge: 8psi to make 300hp on same turbo difrent specs u need 10psi to make 300hp just do a search on turbos there is a red search buton in the top right corner of the page
Old Jul 30, 2007 | 03:04 PM
Kyle R's Avatar
Default Re: Noob Turbo Question (integraRS-T)
The difference is that boost is a measure of pressure and cfm is a measure of airflow.
Old Jul 30, 2007 | 05:05 PM
smileycvc's Avatar
Default Re: Noob Turbo Question (herecomesboost)
yeah I kinda understand. So If you have a ported head and a stock head both running on 8psi with the same everything (besides the head) both motors will be boosting the same amount however the head that is ported will make more power because it is flowing more? It seems to me like that has potential to damage the motor because more air is being forced through the motor faster.
EJ8 GSR-T
Nov 12, 2007 04:21 PM
channy
May 13, 2005 06:23 PM
prabtej_si
Jan 25, 2005 09:02 PM
earl
Dec 19, 2001 08:20 PM
