Need Help, No Start!!
Old Jul 30, 2007 | 12:35 PM
LoooseGSR's Avatar
Default Need Help, No Start!!
Here's the gist of what i have going on:
Soon to be Honda Challenge H2 car
94 CX Hatch
B16 swap
Engine harness completely redone by someone who does harnesses for the company that makes the motor mounts;-)
NO gauge cluster, only autometer mechanical gauges and electrical tach
Car previously had a clifford alarm with remote start, MOST of wiring has been removed by me while carefully avoiding any wires that appear to be OEM.
With the battery connected(new battery), when the key is turned to the 'on' position, the main relay fires and the fuel pump kicks on and cycles like normal. When the key is turned however, all I hear is a 'click' in the engine bay and NO TURN, NOTHING, NOT EVEN AN ATTEMPT.
What do you folks think is wrong? I tried jumping the starter manually, still just got a 'click'. Could it be the starter? or the Battery? Need help ASAP!!!
Old Jul 30, 2007 | 12:41 PM
Dutch_Mofo's Avatar
Default Re: Need Help, No Start!! (LoooseGSR)
What happens when you put 12v directly on your starter?
Old Jul 30, 2007 | 12:47 PM
LoooseGSR's Avatar
Default Re: Need Help, No Start!! (Dutch_Mofo)
just clicks
Old Jul 30, 2007 | 01:40 PM
LoooseGSR's Avatar
anybody?
Old Jul 30, 2007 | 04:37 PM
LoooseGSR's Avatar
someone has to have encountered this before
Old Jul 30, 2007 | 04:44 PM
95DxSi-R2
Guest
Posts: n/a
replace your starter, if your putting 12v direct to the solenoid and it still clicks, your starter is bad, get your multimeter and check the starter case to ground for continuity, if you have less than 5 ohms, get a new starter
Old Jul 30, 2007 | 05:31 PM
LoooseGSR's Avatar
Default Re: Need Help, No Start!! (95DxSi-R2)
i think it's the starter relay or fuse....tried again and it started...thanks for the troubleshooting help folks
Old Jul 30, 2007 | 05:42 PM
95DxSi-R2
Guest
Posts: n/a
what do u mean it just started, did u do anything?
Old Jul 30, 2007 | 10:35 PM
LoooseGSR's Avatar
bridged the positive pole and the starter power, and it started up...so no power is getting from ignition to starter...gonna check fuses and relay...hopefully that's it, will keep you all updated.
Old Jul 31, 2007 | 04:45 AM
Zephyr-The Subaru Guy's Avatar
You'll also want to check your engine grounds, make sure your engine harness is properly grounded in the factory points. Make sure that the ground strap for the engine to chasis is present and that the ground that runs to the transmission area to the battery is present.
It does sound to me as though the starter solenoid is NFG. Try another starter. It's a racecar, you need a spare anyhow.
Z
Old Jul 31, 2007 | 09:11 AM
LoooseGSR's Avatar
Default Re: (Zephyr-The Subaru Guy)
I had the starter tested and it had no problems. NFG? What does that mean?
Old Jul 31, 2007 | 05:06 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: (LoooseGSR)
No ******* Good i'm *** uming
do u know how to use a multi-meter? or a test light?
99Whiteekferio
28
Nov 5, 2013 01:35 AM
prowheelie92
Acura TL, RL & ZDX
Jul 11, 2012 06:26 PM
R-81DC2
May 22, 2006 01:33 PM
ZexyAccord
Jan 9, 2006 03:34 PM
gen3hatch
Sep 14, 2003 01:22 PM
