i think i may have killed the car and the battery
Old Jul 30, 2007 | 09:59 AM
361 accord's Avatar
Default i think i may have killed the car and the battery
ok heres the story, ive got the car hardparkin in the garage and i was dumb enough to leave the keys in the ignition on accesory, possiblt with the radio on for a few DAAYS
the battery is PWNZ0R3D now with out even enough power to turn on a light or anything and when i plugged it in to the chager i have, well it JUMPS THE SCALE pullin hella amps
i did a little ms paint to show where the needles are going
BUT the battery, i can still get a new one for free, the wiring and the car ans stuff is what im worried about!!!
Modified by 361 accord at 1:54 PM 7/30/2007
Old Jul 30, 2007 | 10:17 AM
02 accord's Avatar
Default Re: HEEEELP i think i may have killed the car and the battery (361 accord)
Get a new battery then. The car and wiring should be fine.
Old Jul 30, 2007 | 10:19 AM
02 accord's Avatar
Default Re: HEEEELP i think i may have killed the car and the battery (02 accord)
Better yet, take it to autozone and have them worry about charging it.
Old Jul 30, 2007 | 10:26 AM
361 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Better yet, take it to autozone and have them worry about charging it.</TD></TR></TABLE> im going to take it to autozone later when my mom gets here car wont start
KAH KAH anyone returned a battery to AZ before u need a reciept
Old Jul 30, 2007 | 10:38 AM
Bruce Banner's Avatar
take the batt to the store for a charge.
worst case, get a new battery.
Old Jul 30, 2007 | 12:24 PM
cambodian's Avatar
Default Re: HEEEELP i think i may have killed the car and the battery (Bruce Banner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bruce Banner &raquo;</TD></TR><TR><TD CLASS="quote">take the batt to the store for a charge.
worst case, get a new battery.</TD></TR></TABLE>
Old Jul 30, 2007 | 03:14 PM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361 accord &raquo;</TD></TR><TR><TD CLASS="quote">KAH KAH anyone returned a battery to AZ before u need a reciept
Damet Paul, I thought you knew how to form sentences. Anyway, they should be able to look you up by your phone number that you gave them for the warranty; so no receipt should be necessary.
Old Jul 30, 2007 | 05:26 PM
361 accord's Avatar
Damet Paul, I thought you knew how to form sentences. Anyway, they should be able to look you up by your phone number that you gave them for the warranty; so no receipt should be necessary.</TD></TR></TABLE> the battery.... expletive!! well this is actually the 2nd battery, they screwed up the first one by breaking the case and spillin put all the acid, the sticker on thisn says october 05 so idk
PLUS my moms friend got it, i didnt ,is it xferable?
Old Jul 30, 2007 | 06:40 PM
02 accord's Avatar
If you have a receipt, you will get a new battery. If you have the name and phone number of the person that bought it, you should also get a new battery.
Old Aug 1, 2007 | 09:40 AM
professorman's Avatar
and if one store dont take it, try different stores. I had to try 4 different stores before I got them to take back my motorcycle battery, they telling me that I cant return motorcycle batteries.
Old Aug 1, 2007 | 09:43 AM
didyouhearthat's Avatar
Default Re: i think i may have killed the car and the battery (361 accord)
when the arrows go "up" it means it's dead. When the arrows start pointing toward the bottom is when it is full charge. (see 100%). or something.
Is there also a switch for "deep cycle, maint. free, manual maint. free"?
Old Aug 1, 2007 | 09:49 AM
361 accord's Avatar
Default Re: i think i may have killed the car and the battery (didyouhearthat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by didyouhearthat &raquo;</TD></TR><TR><TD CLASS="quote">when the arrows go "up" it means it's dead. When the arrows start pointing toward the bottom is when it is full charge. (see 100%). or something.
Is there also a switch for "deep cycle, maint. free, manual maint. free"?</TD></TR></TABLE>
ill get some pics, what exactly do you mean by dead, as in no good and wont hold a charge and i can get a new one?
Old Aug 1, 2007 | 09:55 AM
361 accord's Avatar
nvm the pic at the tops shows it, its just a cheap charger, well 35 or something iirc
anyways yeah normally when i drain the battery it will pull 6 amps, like its supposed to this time i think its HELLA DEAD cuz it pulls almost double that and makes a louder than usual buzzing sound
and ive charged batterys with dead cells before, it starts at ~5 amps then goes down to full charge really quick, in a few minutes,
Old Aug 1, 2007 | 10:16 AM
ill get some pics, what exactly do you mean by dead, as in no good and wont hold a charge and i can get a new one?</TD></TR></TABLE>
Dead as in it just needs a charge. Bad is bad, no bueno. Batteria nuevo.
Have you checked the water in the battery? Does it give off a rotten egg odor when charging? I would check the water and add some if it is low, then charge it again.
Old Aug 1, 2007 | 10:35 AM
361 accord's Avatar
so its still OK? idk i ddnt smell it but ive already taken it out of that car, is it OK to charge batterys outside of the car?
Old Aug 1, 2007 | 11:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361 accord &raquo;</TD></TR><TR><TD CLASS="quote">so its still OK? idk i ddnt smell it but ive already taken it out of that car, is it OK to charge batterys outside of the car?</TD></TR></TABLE>
It's recommended that you remove the battery from the vehicle prior to charging.
teddy_dc2
Feb 16, 2017 06:28 AM
92 CIVIC HATCH VX
Feb 22, 2009 10:56 PM
Eighty-Nyne
Nov 12, 2008 07:25 PM
H22CD7
Audio / Security / Video
16
Jan 16, 2007 08:17 AM
Boxcar
16
May 1, 2005 12:54 AM
