looking for the f22b2 stamp on my........
i was cleaning my engine bay brushing off the pounds of dirt that have accumulated over the years and i was looking for the f22b2 stamp on the block and what i saw was h2a. isn't it located over the front motor mount near the exhaust header. YEA i know this is a dumb post
If anything it would be H22A which belongs in the SI-R. So unless you have a swap it will say F22B2.
To facilitate this, is it DOHC or SOHC?
I don't know if you were talking to me in a sarcastic way or asking him. If you were talking to me, I was pretty sure the H22 came in the Accord Si-R and I just checked Honda-swap and I was right. Unless they are wrong too?
It is stamped on the block directly above/behind where the front mount is bolted. If you see the HA you've gone up to far. You may have to take a scotchbrite pad or steel wool and remove some oxidation from the block to see it clearly. Just cleaning off the dirt doesn't always work.
In this image to the right of the engine code is the exhaust manifold, the black at the bottom is the engine mount and to the left is the upper rad hose
Hope this helps
Cheers
Hope this helps
Cheers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bseriescrxsi »</TD></TR><TR><TD CLASS="quote">im taking it he doesnt know what h22 or si-r mean</TD></TR></TABLE>
lol, if available... pressure wash your e-bay.
cmamtower
Oct 23, 2010 08:53 AM
Danny.T
Sep 5, 2010 08:07 AM
