How much is compatible? (F20B/H22A)
Old Jul 29, 2007 | 11:05 PM
Ledo's Avatar
Default How much is compatible? (F20B/H22A)
I'm selling the Altezza I imported from Japan for a little cash and I'll be spending that on trying to turbo my F20B.
Now before everyone points out that the H22A is a better platform with lower compression, OBD1 etc, I'm keen to do the F20B because as far as I know it hasn't been done here in New Zealand. I've got the time and a little money. So why not...
Now the first step for me will be finding out as much as I can about the F20B. How much is interchangable with the H22A. From what I've read the F20B and the H22A heads are pretty much alike, apart from being OBD1/2.
Obviously one of the main issues is going to be OBD2. I'm pretty sure I can source an ODB1 ecu and adapter harness. Only problem is that my F20B's got a nasty Tiptronic mated to it. This leads me to my next question. Which tanny's will bolt up to the F20B block?
So anyway, I know H22A headers/intake manifold will bolt straight up to the block so thats a step in the right direction concerning a turbo manifold. What about head gasket. If its going to be turbo that compression ratio will need to come down wont it. I'm going to be running around 6 - 8 psi. Not much I know but will I need to bring that compression ratio down for that little boost? Will the H22A gasket work on the F20B if it has to come down?
Those are my main concerns. Thanks in advance...
Old Jul 30, 2007 | 11:34 AM
Bense's Avatar
did you see the f20b faq?
Old Jul 30, 2007 | 11:54 AM
Bense's Avatar
Default Re: (Bense)
any f/h trans will bolt up to it
Accord6Gen
Jun 30, 2004 04:49 AM
Neondog82
Jun 18, 2004 01:15 AM
ZXVIIR
Oct 13, 2002 07:38 PM
