Electrical Problem HELP!!!!!!!!!
ok here is my problem I got a 91 civic hatch. the problem is my cluster, my climate control, my Autometer tach doesnt light up when I turn my lights on.
when I put my 4 ways on my turn signals dont light up but the cluster indecators come on and when I put my indacator on my Temp guage on the cluster rises and when I put it off it goes down. my highbeam light doesnt light up on the cluster when I flick the highbeams on
my headlights and highbeams, taillights, brake lights work. also my radio doesnt work. but I am gettin power to my cigg lighter. I ran tests changed fuses checked for ground everything and still problem not solved
does anyone know this problem. it seems like wires are crosses but I double checked and everything is in its place from sum reason its FUCKED! I am in the Toronto area. your help will be greatly appreciated.
sounds like you have a short in the parking light circuit, did you have a fuse on the tach light input?
have you checked that the bulbs themselves are good for the turn signals?
another kind of stupid qustion, did you check the fuses under the hood too?
everything has been checked fuses bulbs but instead of the indecators flashing the engine light is goin on and off seems like the wires are crossed but they arent
