Tranny problem
Ok.. Car is a 95 Civic EX couple. Friday i had to bypass my thermostat for the radiator. I did that and got a new gasket. After that i figured sonce i was already dirty i mine as well get my A/C condensor out of there and get it replaced due to a rock putting a hole through it. So this morning i go to start it up and it sounds fine. Go to drive it and it drives so bad. Its a Auto. I drive regulary and it doesn't want to shift at right RPM. And when it finally does it shifts hard. I hook everything up back the way it was minus the AC lines. And it still does the same. What do you think guys??? I am out of ideas and the fluid is good. Is there any wires in general that i might have hit and messed up
Check to make sure the throttle cable to the transmission is intact and the linkage is not broken. If you break this it will shift hard because this line controls your mainline pressure, as well as shift point control.
when i move the throttle i do see a piece moving on the tranny so i assume what ur talking about is good???? Other than that i have no clue what ur talking about. I don't know about this ****
shortstopNE
Apr 9, 2011 06:46 AM
93hondacivic
Oct 7, 2008 09:57 PM
Next GenRacing
Jun 12, 2005 03:16 PM
