wtf is this and how to remove it (pic)
Old Jul 29, 2007 | 12:48 PM
gursh d's Avatar
Default wtf is this and how to remove it (pic)
so I'm pulling my engine harness off of the d16a6 and ran into a last problem on the last plug. This is the only thing that's left to remove, then the wiring harness will be free. But I don't know if there is a "proper" way to take it off.
I'd figure I'd just pull it, but I don't want to break it considering I'll prob be using this harness for my new OBD1 motor. Below is a pic:
I circled the plug that was giving me trouble and labeled it 1
2 is a plug next to it that I was able to just "pull off" but 1 is giving me a harder time. It's prob something simple...but I don't want to take any chances.
Old Jul 29, 2007 | 12:55 PM
SiR Inspired ED7's Avatar
Default Re: wtf is this and how to remove it (91.crx.si)
Just pull it from the Plastic part & for #2 pull the Black cover back, the black cover might break cause it old... Don'tNot from the wire. It's a lil hard some times
Old Jul 29, 2007 | 01:53 PM
hondacivic90zc's Avatar
Default Re: wtf is this and how to remove it (SiR Inspired ED7)
on mine there were little plastic covers at the tips of the wires were they connect and you just have to pop those up and pull the wire off. It gave me a little trouble too so be patient.
Old Jul 29, 2007 | 06:01 PM
janz3n's Avatar
Default Re: wtf is this and how to remove it (iandavis90)
1 is like 2 .. but its got 2 wires instead of 1. pull the plastic cover back a bit and pull from the actual plug or you'll rip the wire out of the plug.
Old Jul 29, 2007 | 07:24 PM
HondaRexBoi's Avatar
From: IN YOUR BASEMENT, ON YOUR COMPUTER, minesota, united states
the one on the right is the oil pressure sensor, and on the left i think its a nock sensor correct me if im wrong.
Old Jul 29, 2007 | 07:33 PM
Default Re: wtf is this and how to remove it (HondaRexBoi)
you are right on the oil pressure sensor which is used for the dummy light on the cluster but you are wrong on the other one. That is the coolant temp switch for the radiator fan
Old Jul 29, 2007 | 08:33 PM
thank you for the correction
Old Jul 29, 2007 | 11:32 PM
DOHCvTEC96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iandavis90 &raquo;</TD></TR><TR><TD CLASS="quote">you are right on the oil pressure sensor which is used for the dummy light on the cluster but you are wrong on the other one. That is the coolant temp switch for the radiator fan </TD></TR></TABLE>
correct, if you are using an obd1 engine the coolant temp sensor is located on the thermostat housing(where the lower radiator hose connects to the engine) you will need to locate a 2 wire female connector from an obd1 harness, either from a junkyard or stealership. what i did was cut the wires at that connector and removed the wire loom from that section, reloomed the section leaving the 2 wires exposed, the soldered the new sensor onto the old wires green to yellow and black to black, then electrical taped the wires to protect them from the elements. hope this helps.-Anthony
gnd101
Jun 1, 2009 04:44 AM
B-serious
Jul 30, 2006 09:56 AM
projectDx
Nov 14, 2004 03:07 PM
Drew96EJ
Sep 27, 2003 03:20 PM
