V-banded Collector
Old Jul 29, 2007 | 12:42 PM
Synapse Motorsport's Avatar
Default V-banded Collector
After working on a new jig for the last couple days, I am pretty happy with the results. I think the major advantage of the housing is the natural progression of a round collector into the housing without hitting any walls, more of a seemless transition, which we don't see on most t3/t4 flanged collectors.
Old Jul 29, 2007 | 01:01 PM
AROD's Avatar
Default Re: V-banded Collector (Synapse Motorsport)
looks real good morgan....nice job
Old Jul 29, 2007 | 02:49 PM
97Alex's Avatar
Is there a gasket that will be fitted in between the flanges?
Have you ever used v-band flanges for turbo exhaust housing inlets before?
I've been wanting to use them, but I was unsure about leaking.
Old Jul 29, 2007 | 04:18 PM
import2nr88's Avatar
There's usually no gasket... We use them on diesels all the time for the exhaust flange and have yet to have one leak.
Old Jul 29, 2007 | 06:48 PM
*Boostwerks*'s Avatar
Looks great. What turbo is the housing for? Also, what size is that V band?
Old Jul 30, 2007 | 03:23 AM
morgan@synapse motorsport's Avatar
Default Re: (Boostwerks.com)
Its for a gt35r
Old Jul 30, 2007 | 04:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com &raquo;</TD></TR><TR><TD CLASS="quote">Looks great. What turbo is the housing for? Also, what size is that V band?
This v band collector will also work with gt28rs, and the gt30r as well
Old Jul 30, 2007 | 04:41 AM
Kyle R's Avatar
Default Re: (mike@synapse motorsport)
Looks great
Old Jul 30, 2007 | 07:22 AM
hondacivic00's Avatar
very nice work - I've been wondering about leaking as well - glad to see it's working well for you. Kudos!
Old Jul 30, 2007 | 09:55 AM
Default Re: (hondacivic00)
heres a few more pics i snapped of the collector this morning.
Old Jul 31, 2007 | 07:23 AM
cjames235's Avatar
wow thats a really smooth transition into the round collector! looks great!
Old Jul 31, 2007 | 07:26 AM
.RTErnie's Avatar
Default Re: (cjames235)
hit that badboy with a flapwheel and then snap some pics. looks great.
Old Jul 31, 2007 | 10:27 AM
RC000E's Avatar
Default Re: (.RTErnie)
Like Boostwerks asked....what size is the v-band?
Old Jul 31, 2007 | 11:57 AM
HiPsi's Avatar
Default Re: (RC000E)
V bands are really a great alternative to the typical gasket sandwich bolted together. Shouldnt have problems with them leaking, at all. I cant recall seeing this done with turbos that often. So you feel this will improve exhaust airflow into the exducer housing?
Old Jul 31, 2007 | 12:41 PM
Default Re: (HiPsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiPsi &raquo;</TD></TR><TR><TD CLASS="quote">V bands are really a great alternative to the typical gasket sandwich bolted together. Shouldnt have problems with them leaking, at all. I cant recall seeing this done with turbos that often. So you feel this will improve exhaust airflow into the exducer housing?</TD></TR></TABLE>
on a typical t3 flange there is overlap on this new v band flange there is none at all. well see how our testing goes. we have an evo project this is going on, but the b-series will be tested soon. i think the new flanges will have a definate performance advantage over the typical t3.
ill measure the flange dimensions later if i can. i beleive the flange size is tial specific so they might be the only ones to get the clamps from.
Old Jul 31, 2007 | 01:21 PM
Mr.E.G.'s Avatar
can you provide some pics of the exhaust side inlet with the vband on it?
also, does the turbo housing come with a vband or do you put it on yourself?
thanks.
Old Jul 31, 2007 | 04:33 PM
RC000E's Avatar
Default Re: (Mr.E.G.)
Yeah dude....where ya been.....those are Tial's new cast stainless vband housings for GT series turbo's.
Tial openly didn't proclaim huge performance gains. I think this mainly strives to clean up the housing, plus it gives you flexibility on the angle that the turbo is mounted. Your not restricted like you are with a bolt pattern. The benefits of the collector transition was very clear right when these were proposed. It's a nice product...no doubt about it.
Old Jul 31, 2007 | 05:02 PM
ebydrc's Avatar
Banned
were are the 6 in 1's hahaha
Old Aug 1, 2007 | 02:06 PM
Mr.E.G.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Yeah dude....where ya been.....those are Tial's new cast stainless vband housings for GT series turbo's.
Tial openly didn't proclaim huge performance gains. I think this mainly strives to clean up the housing, plus it gives you flexibility on the angle that the turbo is mounted. Your not restricted like you are with a bolt pattern. The benefits of the collector transition was very clear right when these were proposed. It's a nice product...no doubt about it.</TD></TR></TABLE>
sorry, i must have missed the latest issue of "turbo know it all quarterly"
thanks for the info.
Old Aug 2, 2007 | 08:30 AM
ls1_datsun's Avatar
There shouldn't be any overlap on a standard t3, 2 seperate cuts will get you the exact outlet size
I think the biggest advantage is purely weight, HKS has used these housing for awhile now...so they are nothing new. Some will argue the transition in the actual housing is smoother with a round entry vs. a rectangular entry but how much..i dont' know.
Either way looks great
Old Aug 2, 2007 | 08:35 AM
ebydrc's Avatar
Banned
Default Re: (ls1_datsun)
ive read the tial gt42 housing is 8 lbs where the cast are 22lbs
Old Aug 2, 2007 | 09:12 AM
ls1_datsun's Avatar
Default Re: (ebydrc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebydrc &raquo;</TD></TR><TR><TD CLASS="quote">ive read the tial gt42 housing is 8 lbs where the cast are 22lbs
That is correct...
Alot of the Garrett stuff is desiel technology that is intergrated over...Its cheaper on their end lol. Turbo's like the HKS T51r (gt42r equivelent) weigh about what a t3/to4e weighs
Old Aug 2, 2007 | 10:36 AM
RC000E's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the info.</TD></TR></TABLE>
Alright Mrs. Butterworth
There were a good number of threads about it in the FI forum, just figured pretty much everyone had come across it at some point or another.
Old Aug 3, 2007 | 09:44 AM
Mr.E.G.'s Avatar
There were a good number of threads about it in the FI forum, just figured pretty much everyone had come across it at some point or another.</TD></TR></TABLE>
yeah come to think of it i do recall reading about that. my memory is poop.
Old Aug 3, 2007 | 09:58 AM
I got a pm about pricing on these, currently we are selling them for 150+ shipping.
This one will fit the GT28rs, GT30r, and GT35r series of turbochargers.
delslo93
Jan 2, 2005 09:42 AM
opto_isolator
Jul 22, 2004 06:42 AM
mildly.interesting
Jan 27, 2004 03:30 PM
Blown90hatcH
Feb 23, 2003 06:58 AM
