MR2 Wheels on my EJ8
Old Jul 29, 2007 | 06:30 AM
invision's Avatar
Default MR2 Wheels on my EJ8
Hey guys, i was planning to buy some MR2 wheels for my EJ8...just before i buy them, i want to make sure they fit...would they? Here are the specs of the wheel: If its 4x100 it should fit right? Sorry, i'm a noob at cars.
http://www.wheelspecs.com/specs/wheelmodels/3006
Thanks H-T
Old Jul 29, 2007 | 12:22 PM
posHonda's Avatar
if the lug pattern is the same than it should fit BUT if the tires are too wide than itll be a problem.
Old Jul 29, 2007 | 02:15 PM
94CoupeEJ1's Avatar
Default Re: MR2 Wheels on my EJ8 (invision)
The diameter of the hub may be different. Wheels with the same bolt pattern can be sold to fit different cars but different hub centric plastic inserts come with the wheels to make them fit over the hub. If the wheel is sold for the MR2 by a distributer and they don't list the same wheel for a Civic it most likely won't fit. My Borbets will fit older VW's but to make them fit different inserts must be used. Be sure the proper insert for Civics is available before you buy.
Old Jul 29, 2007 | 02:19 PM
doood's Avatar
been there done that
Default Re: MR2 Wheels on my EJ8 (94CoupeEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CoupeEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">The diameter of the hub may be different. Wheels with the same bolt pattern can be sold to fit different cars but different hub centric plastic inserts come with the wheels to make them fit over the hub. If the wheel is sold for the MR2 by a distributer and they don't list the same wheel for a Civic it most likely won't fit. My Borbets will fit older VW's but to make them fit different inserts must be used. Be sure the proper insert for Civics is available before you buy. </TD></TR></TABLE>
exactly. i know with my current miata rims, when my brother used them on his gsr he had to get the hub bored out to fit.
salogni63
Honda Fit
Dec 19, 2012 11:53 AM
Badjazz07
Honda Fit
Aug 20, 2007 07:12 AM
UnionCity LS
Jan 12, 2005 03:50 PM
jdmjohn02
Jan 5, 2004 11:50 PM
ninetyfourintegra
Jan 2, 2004 03:27 AM
