Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Help Needed 95 Odyssey electrical starting problem...
Old Jul 29, 2007 | 06:23 AM
BoRiCuA's Avatar
Default Help Needed 95 Odyssey electrical starting problem...
My wife went to do some grocery's, came out turn the van on put it in reverse and it shut off and wouldn't (stay on) would crank but wont stay on. waited about 5 minutes tried again and it started.
Drove it home which is about 5 miles got in the driveway shut it off, tried to start it back on and won't stay on. it has gas almost half-tank, unloaded the groceries tried to start again and it started any idea as to what is going on here?
Old Jul 31, 2007 | 07:34 AM
cursor's Avatar
Default Re: Help Needed 95 Odyssey electrical starting problem... (BoRiCuA)
check out odyclub.com
Old Aug 1, 2007 | 10:08 PM
stussycole's Avatar
If the van is cranking just fine, but will die when the key is released into the run position, then most probably the ignition switch is going bad.
dc2_daj10
May 27, 2010 02:58 PM
xiztence
May 13, 2010 01:32 PM
mynameizstitch
May 5, 2008 09:09 PM
95greenlude
Dec 24, 2007 07:01 AM
killaj12
Jul 6, 2005 02:18 PM
