vtec wiring diagrams deleted!!!!
Old Jul 29, 2007 | 05:22 AM
93(Civic)EG6's Avatar
Default vtec wiring diagrams deleted!!!!
I have searched honda-tech and google for a vtec wiring diagram for an EK jdm OBD1 b16 swap but i found nothing helpful. Does anyone know where to wire up the one wire vtec solenoid and two wire green connector located right next to the solenoid. I'm trying to do a JDM OBD1 B16 into a 1999 Honda Civic DX Hatch OBD2B. I had orginally had some wiring diagrams saved on ff-squad but the whole site ff-squad seems to be down. Any help is appreciated. Thanks.
Modified by 93(Civic)EG6 at 6:33 AM 7/29/2007
Old Jul 29, 2007 | 05:40 AM
Default Re: vtec wiring diagrams deleted!!!! (93(Civic)EG6)
bump if u can help
Old Jul 29, 2007 | 05:56 AM
does any1 know?
Old Aug 4, 2007 | 05:46 PM
killacam661's Avatar
if you have a vtec harness the single green wire go's to the solenoid, and the black and blue wires go to the green clip.( ground on bottom and blue on top of the green clip)
Old Aug 4, 2007 | 06:10 PM
Luserkid's Avatar
Default Re: vtec wiring diagrams deleted!!!! (killacam661)
Oil pressure switch: Tab is to the ecu (C10 (top row of your 31P plug all the way at the end of the 3 wire row)) Bottom to ground
VTEC solenoid is single wire to ECU (B12 (25P connector)
Oil pressure:
31P
1.2.3.blank. space 5.6.7. space 8.9.10 (oil pressure)
25P
1.2. space 3.4.5. space 6.7.8
9.10.11.12 (VTEC)
hope that makes sense.
KiDDD...
Mar 27, 2012 06:11 PM
Acidcrakker
Nov 8, 2007 02:39 PM
Jakester9500
12
Aug 8, 2007 05:25 AM
93(Civic)EG6
Jul 29, 2007 12:56 PM
ilovemyb16a
May 18, 2006 12:58 PM
