????????yokohama advan?????????????
Old Jul 28, 2007 | 10:06 PM
whiteej1's Avatar
Default ????????yokohama advan?????????????
i was planning on getting some new tires for my ej
i wanted to know which yokohana advans were good in terms of grip and treadwear.
Out of the different advan tires which have the longest life and which tires have the best grip
Old Jul 29, 2007 | 12:55 AM
Honda Rules's Avatar
mmmmmmmmmm..........advans...mmmmmmmmmmm
Old Jul 29, 2007 | 05:12 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: ????????yokohama advan????????????? (whiteej1)
Only a few of the tires with the Advan name have made it to the States, and most do not come in sizes for older Civics.
Why don't you follow the advice in the FAQ stickied at the top of this forum? Then we can give you an appropriate recommendation for your needs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote">Which tires should I get?
This depends on what you're looking to get out of the tire. Make a new topic and tell us what you intend to use it for. <FONT SIZE="4">In that topic, make sure to answer the following questions:</FONT>
- What kind of car you have (year, model, version)
- What size wheels you have
- How the tires will be used (daily driving, autocross/track/dragstrip)
- What kind of weather the tires will be used in (dry, rain, snow)</TD></TR></TABLE>
Old Jul 29, 2007 | 11:19 PM
whiteej1's Avatar
oh ya sorry bout that
well, i have a 1995 honda civic ex
with stock 14 inch rims
the tires will mostly be used in the dry but sometimes in the rain
i take my car to the canyons often so i was lookin for some tires with some grip
Old Jul 30, 2007 | 11:06 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (whiteej1)
Get the Yokohama ES100 tires in size 185/60-14. Very good dry traction, excellent in rain, last a long time (25-40K miles), reasonably priced.
Old Jul 30, 2007 | 08:56 PM
whiteej1's Avatar
alot of people have told me that the es 100's arent that great
what is the treadwear like on the yokohama a032R's?
how long would they last on daily driving?
Old Jul 30, 2007 | 09:01 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteej1 &raquo;</TD></TR><TR><TD CLASS="quote">alot of people have told me that the es 100's arent that great
how long would they last on daily driving?</TD></TR></TABLE>
I've had 4 different sets of ES100's. They're great tires, if you don't mind the lower tread wear. They stick real nicely to the road in diverse weather conditions (humidity, precipitation, etc...).
Old Jul 31, 2007 | 05:05 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteej1 &raquo;</TD></TR><TR><TD CLASS="quote">alot of people have told me that the es 100's arent that great</TD></TR></TABLE>
They're wrong. It's a very good tire. It grips well on dry pavement, is excellent in rain, and lasts a reasonably long time (25-40K miles). You can read more opinions about them here, and see side-by-side comparison tests here.
They're also just about the only good summer tire you can buy in the 185/60-14 size you need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteej1 &raquo;</TD></TR><TR><TD CLASS="quote">what is the treadwear like on the yokohama a032R's?
Probably about 5K miles. The A032R are track tires. They have a lot of downsides for street use. Not only do they wear fast, but they're no good in rain (better than some other track tires, but not as good as just about any street tire) and they won't give you much warning before losing traction.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">I've had 4 different sets of ES100's. They're great tires, if you don't mind the lower tread wear. They stick real nicely to the road in diverse weather conditions (humidity, precipitation, etc...).</TD></TR></TABLE>
I don't know what you mean by lower tread wear. We're on the second set on the GS-R. The first set got over 40K miles and they weren't even worn down to the treadwear indicator bars (although they were getting close by that point). That was longer than any of the other tires we've used on that car.
YMMV, of course.
Old Jul 31, 2007 | 04:02 PM
alexisthemovie's Avatar
i will put in another good vote for the yokohama avs es100's.
they grip very well, but that 25k-40k treadwear does seem ambitious. i have put maybe 300 miles of mountain driving, with about 3000 miles of normal driving and at this rate, i think they will last 12k-15k max.
Old Jul 31, 2007 | 05:47 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (alexisthemovie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie &raquo;</TD></TR><TR><TD CLASS="quote">they grip very well, but that 25k-40k treadwear does seem ambitious. i have put maybe 300 miles of mountain driving, with about 3000 miles of normal driving and at this rate, i think they will last 12k-15k max.</TD></TR></TABLE>
Then something is wrong with your car's suspension, or its alignment, or your tire pressure gauge (assuming you're checking pressures regularly), etc. Otherwise there's no way that the ES100 would only last 12-15K miles, assuming they're properly inflated, mostly normal driving, rotated regularly, used till the treadwear bars show, etc. No way. I know not everyone gets the same treadwear, but it's never off by a factor of three. (And I know that it's possible to get over 40K miles to a set, because I've done it myself.)
Old Jul 31, 2007 | 06:45 PM
i run them at the manufacture specs. toe and caster are at spec, but i am running natural camber (no camber kit). this is causing wear on the inner portion of the tire, but the rest of the tire seems to be going quicker than i had expected.
at this point, i sort of wish i had gotten azenis instead since it never rains here.
Old Aug 1, 2007 | 03:11 PM
Legend of Street's Avatar
Default RE
Mountains driving is fun and will wear out the tires quite a bit. I had multiple sets of Azenis wear out within 3k by going up every night of the week almost. Then again I have a set of them on a Corolla station wagon and those have lasted over 18K already and show very slight signs of wear because its used primarily for driving to and from work on the freeway at the speed limit heh.
I've had customers wear out ziex512's in a Honda Fit in 1 month and he barely put on 8K miles.
Tire life largely depends on driving habits and what you subject the tires to.
Old Aug 7, 2007 | 09:38 AM
kalbs's Avatar
a032R is very popular here in the philippines
Old Aug 7, 2007 | 09:44 AM
those are r compound track tires, not what the op is looking for.
subhu1030
Nov 9, 2008 07:41 AM
IHaveYourThonG
Mar 31, 2008 01:09 PM
JDM-GoldenBoy
May 18, 2007 08:04 AM
JunIntegra
14
Mar 15, 2005 09:15 AM
MarkZeroNine
Oct 17, 2003 02:27 PM
