Need Help from a Painting Pro!!!!
Old Jul 28, 2007 | 06:08 PM
rainmanEK's Avatar
big strong guy
Default Need Help from a Painting Pro!!!!
Well My father and I are in the process of painting his Miata and for some reason we can't keep water from coming out of the gun and messing up the paint. As stupid as this sounds we have 3 in-line filters coming off the compressor and we still get drops of water.
Any Advice???
And another question is it ok to use reducer in the clear coat? If so how much should be used?
Thanks, Eric
Old Jul 28, 2007 | 08:05 PM
ek4shizzle's Avatar
Default Re: Need Help from a Painting Pro!!!! (rainmanEK)
old messed up filters? really dirty lines. maybe the water is coming from the car's hidden spots like gaps, tire well, door handle gaps... dont know what else it could be. do not use reducer in the clear coat. why would you need to anyway? only use recommended activator for ambient temperature and use same brand as the clear youre using. hope this helps
Old Jul 28, 2007 | 09:00 PM
SneezinCD5's Avatar
You need to invest in a good water/oil seperator and as far as reducer in the clear, it all depends on what brand you have. I know my DCU2021 by PPG is 4-1-1.
Old Jul 28, 2007 | 09:07 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainmanEK &raquo;</TD></TR><TR><TD CLASS="quote"> As stupid as this sounds we have 3 in-line filters coming off the compressor and we still get drops of water. </TD></TR></TABLE>
hot air leaving the tank is moving too quick and doesn't have a chance to condense. filters should be at least 25 feet away from the compressor to catch moisture.
i had the same problem and thought about coiling up the hose and setting it in a cooler filled with ice. ended up building this. the 3/4 copper piping has 3 traps and the water seperator has a trap. have yet to see a drop in the third trap, seperator or gun.
go to the manufactures website and read the p sheet.
Old Jul 28, 2007 | 11:36 PM
Pockets's Avatar
don't forget to drain the compressor. you can also use a dessicant trap that screws onto your gun.
Old Jul 29, 2007 | 03:32 AM
rainmanEK's Avatar
big strong guy
Default Re: Need Help from a Painting Pro!!!! (ek4shizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4shizzle &raquo;</TD></TR><TR><TD CLASS="quote">old messed up filters? really dirty lines. maybe the water is coming from the car's hidden spots like gaps, tire well, door handle gaps... dont know what else it could be. do not use reducer in the clear coat. why would you need to anyway? only use recommended activator for ambient temperature and use same brand as the clear youre using. hope this helps</TD></TR></TABLE>
The water is coming from the compressor and it does not matter if we drained it or not!
And I wanted to reduce it to make more. Everything has to be re-sprayed because of the water issue!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
go to the manufactures website and read the p sheet. </TD></TR></TABLE>
Ok cool! That must be the problem!
Thanks, Eric
JDM_SOHC
Paint and Body
18
Oct 7, 2009 01:22 PM
lude98SH
Paint and Body
May 7, 2008 07:58 PM
TonyRomo
Paint and Body
Mar 11, 2008 03:35 AM
INVALID
Sep 23, 2002 12:29 AM
