my o2 keeps blowing out...WTF???which one o2 sensor to get?
Old Jun 10, 2002 | 06:40 PM
uneekcrx's Avatar
Default my o2 keeps blowing out...WTF???which one o2 sensor to get?
every time i put a new o2 in my car after a few good runs it goes out check engine light is there a better one wire o2 to get to maybe keep from having this happen? i'm running a little rich but nothing to extreme i think it's just from the extreme heat that's causing the fouled o2 but i'm not sure.....any suggestions?
Old Jun 10, 2002 | 08:42 PM
Flamenco-T's Avatar
Default Re: my o2 keeps blowing out...WTF???which one o2 sensor to get? (uneekcrx)
you're using a one wire O2 sensor ?
I have an extra one...wanna buy it ? make me an offer, it' used
Old Jun 11, 2002 | 12:39 AM
hatchy's Avatar
When you remove the O2 sensor, is it wet? If it is, your motor may be blown and you are spraying oil. You can try cleaning your O2 sensor with brake cleaner.
Old Jun 11, 2002 | 04:16 AM
uneekcrx's Avatar
Default Re: my o2 keeps blowing out...WTF???which one o2 sensor to get? (hatchy)
no i still have a good motor no oil or anything on it just a lot of carbon build up.....can i really use brake cleaner to clean it? i thought i wasn't supposed to touch the sensor or it would damage it?
Old Jun 11, 2002 | 05:05 AM
CovertFI's Avatar
why would you use a one wire o2. is that just a non heated one?
Old Jun 11, 2002 | 05:19 AM
hatchy's Avatar
I've used brake cleaner a few times on my O2 sensor and no problems... your milage may vary.
Old Jun 11, 2002 | 03:18 PM
uneekcrx's Avatar
that's the wire that went into my crx so that's what i replaced it with
and so you're saying that brake cleaner doesn't mess up the o2 sensor?(it's brand new but went out after a few days of carbon build up
1993eghatch
Sep 24, 2010 05:52 PM
odishaw
Feb 16, 2008 08:34 AM
King V
Nov 30, 2007 04:40 AM
creuger
Nov 15, 2002 07:11 PM
radiac
Jul 5, 2001 08:45 PM
