changing rear brake pads, need help
Hey guys i am trying to replace my rear brake pad on my k4 gsxr 600 and i have a question: How do I press the pistons in to slide in a new pad? Do i need to bleed the brakes to do that or is there an easier way??? Please any input would be helpfull at this point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZexyAccord »</TD></TR><TR><TD CLASS="quote">Hey guys i am trying to replace my rear brake pad on my k4 gsxr 600 and i have a question: How do I press the pistons in to slide in a new pad? Do i need to bleed the brakes to do that or is there an easier way??? Please any input would be helpfull at this point.</TD></TR></TABLE>are you sure the piston is not a screw in type? Usually the piston will look like this + If it is, you would rotate the piston counter clockwise. You will not need to bleed your brakes as long as you do not remove the brake line.
