over heating h22a!!!!!??????
Old Jul 28, 2007 | 11:19 AM
ludedude1984's Avatar
Default over heating h22a!!!!!??????
i busted a top radiator hose the other day. i replaced the hose put new fluid in new thermostat and bled the system. still over heats. WTF should i try a 160 thermo? i am also pretty damn sure its not a warped or cracked head. some times it will not over heat and then others it just sky rockets.
Old Jul 28, 2007 | 11:23 AM
shrirag's Avatar
Default Re: over heating h22a!!!!!?????? (ludedude1984)
does your fan turn on at all, I had a problem like that on my 5th gen, but I just gad to get a new switch for my fan.
Old Jul 28, 2007 | 11:24 AM
Default Re: over heating h22a!!!!!?????? (shrirag)
fans work
Old Jul 28, 2007 | 11:33 AM
some one has to have some kind of advice cause im out of ideas.
Old Jul 28, 2007 | 12:06 PM
93sivtec's Avatar
It sounds like your thermo is sticking closed....replace it and flush the system,refill with water and water wetter,no coolant,bleed all air and yu should be good to go.
Old Jul 28, 2007 | 12:29 PM
Default Re: (93sivtec)
water wetter? no coolant after the flush?
Old Jul 28, 2007 | 01:07 PM
Giant_Bean's Avatar
Default Re: (ludedude1984)
air bubble? did you bleed the system?
Old Jul 28, 2007 | 01:41 PM
93sivtec's Avatar
You can use coolant if you really want,but the watter wetter actually keeps temps lower with just water and the w.w.,as oposed to coolant and w.w.
It works great and is race and road proven.Just make sure if it reaches below freezing temps where u live....u swap out at end of summer for anti freeze,because it provides no cold weather protection.
Old Jul 28, 2007 | 01:59 PM
so what is the propper bleeding tecnique for bleeding the system. i know there is a bleeder valve by the thermostat but is there somthing else here im missing
Old Jul 28, 2007 | 03:08 PM
sombora's Avatar
loosen the bleeder valve till the contant stream of fluid comes out....do it till there are no more bubbles coming out
Old Jul 28, 2007 | 05:11 PM
preludefien
Guest
Posts: n/a
Default Re: (sombora)
i will assume that you have checked the head gasket. do you smell it burning or see it smoking when you it gets hot
Old Jul 29, 2007 | 12:26 PM
117's Avatar
117
Are the upper and lower rad hoses getting warm as the engine heats up?
Old Jul 30, 2007 | 09:16 AM
PrecisionH23a's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">Are the upper and lower rad hoses getting warm as the engine heats up?</TD></TR></TABLE>
If the bottom one is cold and the top one is hot the thermo isn't opening. The proper way to bleed your system is to run the car without the radiator cap on until the fans kick on twice. I find that you can squeeze the bottom hose to allow the coolant to flow a little better.
After the fans kick on, throw the radiator cap on then bleed the screw on the tstat housing. Switching to a lower temp tstat will do nothing but give you an improper warm-up.
Old Jul 30, 2007 | 11:23 AM
Maharajamd's Avatar
Amen. Screw the low-temp thermo. And screw WW and water. Fix your problem and you won't have to cut corners like that.
And it sounds like your thermo isn't opening. You can always pull it, boil and it watch to make sure it works.
Old Jul 30, 2007 | 11:43 AM
eggie75's Avatar
gl man. i've been dealing w/ cooling issues for 2 yrs. to me, sounds like you have air in the system, but here's a few things to try.
-if you already replaced ur thermo, make sure u use an oem thermo
-bleed the system
-make sure your fans are coming on when their supposed to - if not, check the fuse and the relay.
-check all grounds
-try flushing the whole system w/ a chemical flush (i'm gonna try this one when i get a chance)
just a few...
Old Jul 30, 2007 | 11:56 AM
Maharajamd's Avatar
What exactly are the benefits to a chemical flush?
Old Jul 31, 2007 | 03:25 AM
eggie75's Avatar
someone recommended it to me. said it gets out alot of build up in the system. alot more than water alone. i havent' tried it yet. when i went to the store to buy one, they had a basic one that you just run through the system for 10-15mins, and another one that you leave in and drive 2-6 hrs. i'm gonna try the latter when i have some time.
Old Jul 31, 2007 | 11:52 AM
prelude-all-the-way's Avatar
Default Re: (eggie75)
This thread is great because my h22a was overheating and i checked the fluid it was full then i went to the hoses the bottom 1 was barely warm the top was super hot took out the thermo and it looked rough so i ordered 1 from the dealership so hopefully thats the problem
Thanks Rob
Joshable14
Jul 20, 2015 10:10 AM
the171
Apr 17, 2011 12:36 PM
team 15
Jun 15, 2009 07:14 PM
Nameless Warrior
10
Dec 16, 2006 07:27 AM
175Shot4Door
Sep 18, 2006 07:51 AM
