Is the Legend GS caliper bracket used??
I think I've decided on an brake combo for 96 LX 4 door:
Legend GS calipers (loaded with pads and bracket)
96 Accord V6 rotors
My question:
Do I use the brackets that come with the calipers or do I need ones for the rotors?
Also, which pads, legend or V6?
I have read all of the upgrade articles and just don't know about these issues.
Thanks in advance.
96 Accord V6 rotors
My question:
Thanks in advance.
Hm, from reading the other threads you're to use 23T brackets if doing a rotor over hub conversion as well. If not, then 25T brackets, though 28T brackets will work as well though there will be issues when your pads get worn down.
i really dont see the problem with using a 28t as long as you dont wear your pads down to the service limit. though even if u did, i am not sure it would cause too much trouble, but i personally have never tired to run it that low, so i cant be sure either way.
i mean its not like the piston is on the verge of popping out or anything, its far from it.
I ended up finding a deal on some rebuilt V6 calipers with brackets, new pads and new rotors ($50 for all). I went that route. I have no idea what the brakes felt like before because I never drove the car (bought it with a blown motor) but, these brakes feel great. They have PLENTY of stopping power, I had to use it when someone almost stopped in front of me from 65 MPH).
Thanks for the input though.
Charlie Moua
Sep 30, 2009 03:26 PM
SearchBeforeUPost!
Jun 8, 2003 07:58 AM
