b16 tranny with b18a internals??
Old Jul 28, 2007 | 05:19 AM
allhonda's Avatar
Default b16 tranny with b18a internals??
is it posible to install the internals of my b18a cable tranny into a b16a hydrolic case i need it for my new eg!!
Old Jul 29, 2007 | 02:40 PM
allhonda's Avatar
Default Re: b16 tranny with b18a internals?? (allhonda)
any body
Old Jul 29, 2007 | 02:44 PM
RyanA's Avatar
What year B18A?? If it's a small shaft, I don't think you can. If it's the 92-93 large shaft cable trans, the internals should just swap out.
Old Jul 29, 2007 | 03:09 PM
allhonda's Avatar
Default Re: b16 tranny with b18a internals?? (RyanA)
yeah its actually a 93 so you say it shoul work?? what about the diferential, the b16 has a broken gear but the diff. is in good cond. and is LSD, can i use with the ls internals??
Old Jul 29, 2007 | 03:41 PM
RyanA's Avatar
Well, you are in luck with the carrier. B16 and LS trannies share the same bolt pattern for the ring gear/carrier. GSR and Type R use a different pattern.
This should help you out quite a bit on your swap, too. I know they are putting hydro internals in a cable but as long as you have the case listed for your cable trans, they will go in your hydro trans.
http://www.outlawatvclub.com/u....html
Old Jul 29, 2007 | 04:20 PM
allhonda's Avatar
thanks man thats some great help you got me ill start working on it this week!!!
ef9civicgen4
May 29, 2008 03:26 AM
taggart_lumpy
Feb 11, 2007 06:11 PM
Drew17th
11
Feb 13, 2006 07:19 PM
XSIWANNAB
Nov 29, 2005 05:04 PM
my ride
Sep 28, 2004 02:15 AM
