Our K-series hatch almost in the 10's on 22" slicks
Old Jul 27, 2007 | 10:56 PM
Humble Performance's Avatar
Default Our K-series hatch almost in the 10's on 22" slicks
We went to the track today and we managed to better our best time. This was done at only 10 psi, pump gas and 22" slicks.
Best run - 11.0
Best mph - 128
The 11.2 run was going to be like an 11.1 or 11.0 but it shut off as soon as I went into 5th. It felt like it might have went to 11 psi in fifth and it hit boost cut since we still have the stock MAP sensor and it still coasted to an 11.2@116 mph. The run right before that one was 11.3@128 mph at only 10 psi and 91 pump gas.
I can't wait to put the 24" slicks and a good clutch to see what it will do.
Modified by Humble Performance at 6:59 PM 8/17/2007
Old Jul 27, 2007 | 11:24 PM
s4yama's Avatar
Default Re: Our K-series hatch almost in the 10's on 22" slicks (Humble Performance)
with the bigger slicks and a better clutch, wont that slow you down?
Old Jul 28, 2007 | 03:20 AM
DaveF's Avatar
Default Re: Our K-series hatch almost in the 10's on 22" slicks (s4yama)
do you still have Jasons crx ?
Old Jul 28, 2007 | 04:45 AM
Adriano's Avatar
Default Re: Our K-series hatch almost in the 10's on 22" slicks (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">with the bigger slicks and a better clutch, wont that slow you down?</TD></TR></TABLE>
The car will hook better and loose MPH (not much) but will run better ETs.
Old Jul 28, 2007 | 05:25 AM
ITR1299PR's Avatar
Great timesss that car is fast.
Old Jul 28, 2007 | 06:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">do you still have Jasons crx ?</TD></TR></TABLE>
No the car is in P.R. right now.
Old Jul 28, 2007 | 10:06 AM
allmotorhatch's Avatar
How much does the car weigh?
Old Jul 28, 2007 | 10:46 AM
Default Re: Our K-series hatch almost in the 10's on 22" slicks (allmotorhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorhatch &raquo;</TD></TR><TR><TD CLASS="quote">How much does the car weigh?</TD></TR></TABLE>
2,200 lbs w/driver
Old Jul 28, 2007 | 10:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s4yama &raquo;</TD></TR><TR><TD CLASS="quote">with the bigger slicks and a better clutch, wont that slow you down?</TD></TR></TABLE>
Why would it slow it down ? It is spinning the tires and I am running out of gear really fast. Those runs were just going through the gears , no power shifting yet so I know it still has some more in it.
Old Jul 28, 2007 | 11:50 AM
06dc5's Avatar
thats cool
Old Jul 28, 2007 | 01:18 PM
humbleg's Avatar
Default Re: (06dc5)
high 10's a comming
Old Jul 28, 2007 | 01:35 PM
SpeedSceneScott's Avatar
Default Re: (humbleg)
Just got a Spec brand clutch and flywheel for my K24 powered CRX. Its the Speed Scene Live TV project car.
Man, the Spec stuff is really high quality. I cant believe how nice is it.
Try one of their clutches in your car. They have stock, and full race stuff available.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by humbleg &raquo;</TD></TR><TR><TD CLASS="quote">high 10's a comming </TD></TR></TABLE>
Soon.
Old Jul 28, 2007 | 10:14 PM
s4yama's Avatar
what kind of clutch set up are you planning on running?
Old Jul 28, 2007 | 10:19 PM
Kyle R's Avatar
Old Jul 29, 2007 | 01:40 AM
Default Re: Our K-series hatch almost in the 10's on 22" slicks (herecomesboost)
Update :
We went to the track tonight and here is the run down :
1st run - 11.3@123
2nd run - 11.1@124
3rd run - 11.0@126
4th run - valve stem came off As soon as I launched I knew there was a problem. This was done on some very old 24x7" slicks , once we get a set of new 24.5x9 I know the car has some 10.80's in it no problem. This was done still at only 10 psi !!!
Old Jul 29, 2007 | 02:01 AM
Kyle R's Avatar
Wow. Soooo close. Best of luck
Old Jul 29, 2007 | 02:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost &raquo;</TD></TR><TR><TD CLASS="quote">Wow. Soooo close. Best of luck </TD></TR></TABLE>
Thanks man !
Old Jul 29, 2007 | 11:49 PM
s4yama's Avatar
whats your 60'like?
Old Jul 30, 2007 | 06:46 AM
That was another thing , we were only cutting 1.72 60 ft times because the 2 step was at 5,500 rpm but we did not have the laptop with us to raise it up. I know if I raise it up to 6,500 with the bigger slicks we can cut some high 1.6's .
Old Jul 30, 2007 | 08:01 AM
game over's Avatar
10s coming soon!
Old Jul 31, 2007 | 03:59 PM
b20beast978's Avatar
good luck with 10's your almost there!
Old Aug 1, 2007 | 07:29 AM
game over's Avatar
thanks man
Old Aug 1, 2007 | 12:51 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Great clutch at your service sir, let me know what we can do.
Humble Performance
Old Aug 1, 2007 | 12:55 PM
Default Re: Our K-series hatch almost in the 10's on 22" slicks (DAantagonist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote">Great clutch at your service sir, let me know what we can do.
Humble Performance</TD></TR></TABLE>
Thanks man !
We are going to get it in the next couple of days.
