---> oil sandwich adaptors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy »</TD></TR><TR><TD CLASS="quote">stock FTW</TD></TR></TABLE>
What are you on, because I want some.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 »</TD></TR><TR><TD CLASS="quote">Canton
Assuming you want it for a cooler.... its the only sandwich plate that seems to be available with 1/2" ports in it.</TD></TR></TABLE>
actually wanting it for turbo oil feed and sender.
there are so many out there. i really just want one that goes through the filter first before it goes out the ports and one that wont leak..
just looking for suggestions.
Assuming you want it for a cooler.... its the only sandwich plate that seems to be available with 1/2" ports in it.</TD></TR></TABLE>actually wanting it for turbo oil feed and sender.
I have a Golden Eagle sandwich. You can find them pretty cheap used, and they work really well. Endyn makes an adapter that has a beefier bolt thingy than the Golden Eagle, but I have no personal experience with that sandwich (although Endyn definitely knows their ****). Both of them send oil through the filter first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si GUY99 »</TD></TR><TR><TD CLASS="quote">greddy makes one ...i just ordered mine the other day</TD></TR></TABLE>
One that uses filtered oil for feeds?
The GE plate is the one you want. The 1/8"NPT threads are a little bit tight, but it's otherwise a fine piece. It could be cheaper.
I'm using a GReddy one for turbo feed and oil pressure. I also got the fittings to adapt the larger port to -6AN in case I ever toss a VTEC head on, but it's still capped off for now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">I'm using a GReddy one for turbo feed and oil pressure. I also got the fittings to adapt the larger port to -6AN in case I ever toss a VTEC head on, but it's still capped off for now.
fwiw -6 is overkill for a ls vtec. -4 is optimal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akira712 »</TD></TR><TR><TD CLASS="quote">
One that uses filtered oil for feeds?</TD></TR></TABLE>
and that matters why? most people just use it from the back of the block, thats not filtered, the **** ends up getting filtere anyway, im using a greddy, no problems here, i did have to have it retapped thouhg cause it uses some weird thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
...i did have to have it retapped thouhg cause it uses some weird thread.</TD></TR></TABLE>
metric measurements owns you...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune »</TD></TR><TR><TD CLASS="quote">
metric measurements owns you...</TD></TR></TABLE>
bah what ev, i had all the ish needed to retap it so it was no biggy, i just had a friend do it so i wouldent *** it up.
