tranny swap... I need some help.
Old Jul 27, 2007 | 07:09 PM
The Dirty EJ1's Avatar
Default tranny swap... I need some help.
Im swaping a z6 tranny out for a y8 tranny... Well one of the little alignment things are still on the motor and also one is on the new tranny, so my question is how do I remove those things? I tried pliers but neither of them will come out. help please! THANKS!
Old Jul 27, 2007 | 07:14 PM
forcefedferio's Avatar
Default Re: tranny swap... I need some help. (The Dirty EJ1)
try applying a little bit of heat to the case around the alignment dowel, using map gas or even a propane torch, keep working at it with the pliers and it should come out, if anyone has a simpler solution then you can try that as an alternative as well.
Old Jul 27, 2007 | 09:54 PM
Default Re: tranny swap... I need some help. (forcefedferio)
bump before bed.
Old Jul 28, 2007 | 08:24 PM
Mista Bone's Avatar
D Tranny Guru
insert a 3/8" short extension, then lock down with vise grips, twist to break loose the dowl, then twist and pull......
Blacknight117
Jun 17, 2011 06:26 AM
MildWater
Mar 10, 2007 07:32 PM
big-cat
Oct 8, 2006 05:41 PM
big-cat
Oct 6, 2006 07:57 PM
OG SHG_EM1
25
May 4, 2005 12:41 PM
