Cracked a sleeve.. UGH
Old Jul 27, 2007 | 05:28 PM
EGSR-T's Avatar
Default Cracked a sleeve.. UGH
Sooooooo, I'm on my way home from work, and this idiot cuts me off and flys past me like a bat outta hell, I HATE that, so I downshift and the instant I did, I filled the road with smoke, I'm thinking to myself, hmm that's odd??
Get the car home, inspect it, visibly everything is fine, tear the head off, and WOW, cyl #2 sleeve is cracked in 3 spots, drop the pan and my arp rod bolt only had one nut on it.. Talk about a shitty day..
Oh well, turbo kit is now off the car, cleaned up, and for sale to fund my k-swap.. Gonna do a k24/k20, 6spd, kpro, nitrous.. Done with boost for awhile, stay tuned for some pics maybe tomorrow?
Old Jul 27, 2007 | 06:34 PM
vtec4max's Avatar
good story, love to see them pics. how much power you putting out anyway?
Old Jul 28, 2007 | 04:57 AM
EGSR-T's Avatar
Default Re: (vtec4max)
Was only making 287whp on 13psi, guess it was just time for the motor to go, bought it used so it had god knows how many miles on it, all I did was have some ARP headstuds and rodbolts installed, otherwise it was stock..
The K, is gonna be fun
Old Jul 28, 2007 | 05:07 AM
DaveF's Avatar
Default Re: (EGSR-T)
this all seems extremly stupid to me, for you to try to swap to k from a small mishap like this. you can pick up another longblock for alot cheaper than it will cost you for a "blingin" k series.
Old Jul 28, 2007 | 07:07 AM
RSX_012's Avatar
Default Re: (dturbocivic)
blingity blahhhw
k series are the sex.
Old Jul 28, 2007 | 07:09 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (RSX_012)
K series are nice, but too damn expensive... Way too expensive.
Old Jul 28, 2007 | 10:19 AM
vtec4max's Avatar
287HP only huh? it's still odd that the cylinder wall couldn't hold up....
Old Jul 28, 2007 | 11:04 AM
1fastEK9's Avatar
instead of spending your $$$ on a K-series you should get the block sleeve and new pistons and rods
Old Jul 28, 2007 | 11:39 AM
posHonda's Avatar
what was it tuned on? stock sleeves shouldnt crack with only 287whp. how long have you had the setup on there?
Old Jul 28, 2007 | 11:56 AM
EGSR-T's Avatar
Default Re: (iVteC_PoWeR)
it was tuned on uberdata, nothing special..
and guys, ive wanted to do a k swap for awhile now, this just gives me the excuse to do it.. ive already got the tranny, mounts, axles, shif box, etc.
I still have no clue why the one sleeve cracked, it wasn't alot of power at all, but it looks horrible.. lol
Old Jul 28, 2007 | 12:02 PM
nvmeplz's Avatar
Don't go and blow the K now.
Old Jul 28, 2007 | 12:38 PM
GetawayInMoscow's Avatar
Default Re: (nvmeplz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nvmeplz &raquo;</TD></TR><TR><TD CLASS="quote">Don't go and blow the K now.</TD></TR></TABLE>
He will.
Old Jul 28, 2007 | 12:41 PM
posHonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGSR-T &raquo;</TD></TR><TR><TD CLASS="quote">it was tuned on uberdata, nothing special..
I still have no clue why the one sleeve cracked, it wasn't alot of power at all, but it looks horrible.. lol</TD></TR></TABLE>
if you want to do a K swap than go ahead. theres nothing wrong with it. people suggest other options because more power can be had for less money. a K motor is a great option
Old Jul 28, 2007 | 12:42 PM
vtec4max's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">
if you want to do a K swap than go ahead. theres nothing wrong with it. people suggest other options because more power can be had for less money. a K motor is a great option</TD></TR></TABLE>
X2
Old Jul 28, 2007 | 02:16 PM
93supercoupe's Avatar
Default Re: (GetawayInMoscow)
what makes u say that?
seems like his last setup was done right, so i see no reason for it happening on a new K.
Old Jul 28, 2007 | 02:26 PM
posHonda's Avatar
Default Re: (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">what makes u say that?
seems like his last setup was done right, so i see no reason for it happening on a new K.</TD></TR></TABLE>
everyones telling him not to do a K swap and there have been many successful ones. sure that happened no his last setup but our motors were never made to have a turbo so sometimes things will go wrong unexpectedly. should a stock sleeve crack with only 287whp? no. but the motor could have been worn, had high miles, and who knows what else. he can afford it so starting with a strong, low milage motor is never a bad idea. if he can fund it than why should people bash him for it?
Old Jul 28, 2007 | 02:31 PM
1Quikgsr's Avatar
Default Re: (1fastEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastEK9 &raquo;</TD></TR><TR><TD CLASS="quote">instead of spending your $$$ on a K-series you should get the block sleeve and new pistons and rods </TD></TR></TABLE>
it probably blew because of the tune
Old Jul 28, 2007 | 05:24 PM
EGSR-T's Avatar
Default Re: (1Quikgsr)
My tuner didn't sound so sure that it wasn't his fault.. I told him what happened, and he assured me it was timing, if there were any issues with the timing, they should have been fixed on the dyno, but he didn't mention it..
The K will be done right, I'm gonna build it while it's out, I'll have less than 3500 into the swap, I've got the type-s tranny, hybrid racing mounts, base model axles, ry-wire harness, 4puck clutch kit, shift box, just need to find a cheap k24 shortblock (condition doesn't matter as I'm gonna rebuild it anyway) and a type-s head, which I may be picking up off ebay this weekend if the auction doesn't get too high..
I've been planning on doing this swap for awhile, buying one piece at a time, but this little issue has pushed me to complete it sooner, car will be daily driven with ice cold a/c
Old Jul 28, 2007 | 05:37 PM
Blackturboteg's Avatar
What ill u be selling
Old Jul 29, 2007 | 12:45 PM
EGSR-T's Avatar
Default Re: (Blackturboteg)
As of right now the complete turbo kit is off the car and for sale, have a pending sale that I hope goes through..
A JDM ITR 4.7fd LSD tranny with a centerforce DFX clutch kit
skunk2 intake manifold for a gsr
b-series into eg hasport mounts
b-series into eg linkage
b-series gator stg2 axles
and a stock jdm gsr crankshaft that looks to be in good shape..
Old Jul 30, 2007 | 07:45 PM
how much for the tranny?
Old Jul 30, 2007 | 07:50 PM
agrn93ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGSR-T &raquo;</TD></TR><TR><TD CLASS="quote">My tuner didn't sound so sure that it wasn't his fault.. I told him what happened, and he assured me it was timing, if there were any issues with the timing, they should have been fixed on the dyno, but he didn't mention it..
The K will be done right</TD></TR></TABLE>
can we get the name of the tuner to put on the dont take it to this guy list lol..
good luck with the next build
Old Jul 30, 2007 | 08:26 PM
Schister66's Avatar
Man U FTW
wow....how does that happen at such a low power level???
Old Jul 30, 2007 | 08:42 PM
red02s2k's Avatar
that does suck!!! have fun doing the and lets see sume pic's of the sleeve
Old Jul 31, 2007 | 07:21 AM
EGSR-T's Avatar
Default Re: (red02s2k)
The tuners name is gonna be kept personal, I'm not blaming it 100% on him, the motor came from a 94 gsr with god only knows how many miles on it, but I didn't care too much as it's not my daily driver, its seen 320+whp a few times when my wastegate was freaking out and making boost spike like crazy..
I haven't had a chance to go mess with it due to work, the sleeve looks horrible though, pics will be up soon..
If you guys know of ANYONE interested in the turbo kit, that is only about 5-6 months old, let me know, it comes with both D and B drag a/c friendly log mani's, ill throw in a chipped p28 and everything, link here:
https://honda-tech.com/zerothread?id=2054496
