Aluminum Head welding in Northern Virginia Needed!
Old Jul 27, 2007 | 03:07 PM
FastCougar's Avatar
Default Aluminum Head welding in Northern Virginia Needed!
I need someone who can weld in an injector valley in 2 heads. There are 3 valleys per head, so 6 total. Here is what I have done in the past:
Rather than have the heads welded, I filled them with a metal filler. My buddy wants me to part match his heads, but wants the valleys welded instead of filled.
Cut in new "valley"
Fill old valley & shape
So, instead of using metal filler, I want them welded first, then I can shape them when I do the port matching.
Anyone in NOVA that can do this and if so, how much?
Old Jul 27, 2007 | 05:06 PM
905_Legend's Avatar
Default Re: Aluminum Head welding in Northern Virginia Needed! (FastCougar)
you have to port match it for a 3L bottom end eh, I've had a few heads welded. Most welding shop should be able to do it because that part of aluminum won't be soaked with oil.
Old Jul 27, 2007 | 05:08 PM
new2novas's Avatar
Default Re: Aluminum Head welding in Northern Virginia Needed! (905_Legend)
there is an epoxy that they use for this sort of thing...i see it in v8 stuff when they raise the runner walls and fill the floors, not sure what its called, a good machine shop should know
Old Jul 27, 2007 | 05:22 PM
FastCougar's Avatar
No, these are 3L heads going on a 3L block, but we are using the 2.5L SVT Split port LIM, so the oval port "tumble" heads needs to be matched to the 2.5L split port LIM. The heads will be factory new since they are being hot tanked and disassembled, so I don't have to work about shavings getting in the valve seats and such.
Old Jul 27, 2007 | 07:23 PM
all_motor_mike's Avatar
i no im not in virginia but i could resist saying that i could take care of that.
Old Jul 28, 2007 | 03:14 AM
dfoxengr's Avatar
Default Re: Aluminum Head welding in Northern Virginia Needed! (all_motor_mike)
id give it a shot i suppose.
b16civster
21
Jan 7, 2007 08:34 PM
Tech6023
Oct 12, 2005 06:17 AM
MooFX
Oct 1, 2004 10:19 AM
XLR8 GS-R
Apr 23, 2004 06:05 PM
mycvc8u2
Jul 21, 2003 10:50 PM
