1995 accord Lx. driver side window switch not working. but the others are???
i have a 1995 Accord LX and in the driver side, the window switch is the working but only the the driver window switch. all the other switchs for the other windows are just great. its not the 1st time ive seeing this problem happen, my friend had the same problem but got the car stolen and we never found out what it was. i already check that all the cables behind the door panel are well connected.
can anyone help?
can anyone help?
Just got done with the same thing on my g/f's car and it was the switch assembly itself. Her's was fried only on the 'up' portion if the switch, but the down worked just fine, and so did all the others.
Unfortunately, it is an integrated unit, meaning that you cannot simply swap a working rear seat switch to the front slot where your broken one is. All you can do is buy a new one on ebay as those are about the cheapest I've found. Even at junkyards, they are still way spendy because this is a common thing to happen.
