Battery keeps draining
Old Jul 27, 2007 | 12:11 PM
itr501's Avatar
Default Battery keeps draining
I didn't drive my car for a week and a half and when I finally decided to start her up, the battery was completely dead. This happens to me every time I store the car for more than a week. I don't think the battery is at fault here because it's fairly new. Anyone have any ideas?
Old Jul 27, 2007 | 12:21 PM
cmdr430's Avatar
Default Re: Battery keeps draining (itr501)
alternator?
maybe a bad ground or lead?
edit: what is fairly new?
Old Jul 27, 2007 | 12:24 PM
Cheeze's Avatar
Default Re: Battery keeps draining (cmdr430)
Do you have any alarm installed? If so. that can be the caused. If you plan on not driving your car for over a week, i would unhook the battery.
Old Jul 27, 2007 | 12:26 PM
nholmes's Avatar
Do you have some ricer lights and **** in your car? Crazy sound system? What electronics do you have in your car and who installed them?
Do you have a volt meter? You can use that to try and find any bad grounds you may have.
Old Jul 27, 2007 | 02:30 PM
JjuuN R's Avatar
Default Re: (nholmes)
If it still drains while driving, it's your alternator...
Other then that it could be anything anyone else said in here...
Old Jul 27, 2007 | 03:15 PM
grjp1988's Avatar
when you car is completely off, take the negative wire off your battery and scratch the negative wire against the where you just took it off from and if it sparks theres a short.
Old Jul 27, 2007 | 05:01 PM
1GreyTeg's Avatar
don't forget to check the glovebox light.
but yeah once week is kinda excessive.
Old Jul 27, 2007 | 05:15 PM
get RIGHT's Avatar
Default Re: Battery keeps draining (1GreyTeg)
If you have an alarm that is draining it you should look into getting a Deep Cycle battery.
Old Jul 27, 2007 | 05:18 PM
1GreyTeg's Avatar
Default Re: Battery keeps draining (get RIGHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by get RIGHT &raquo;</TD></TR><TR><TD CLASS="quote">If you have an alarm that is draining it you should look into getting a Deep Cycle battery.</TD></TR></TABLE>
or just remove the alarm. because historically alarms have never saved R's.
Old Jul 28, 2007 | 05:14 AM
stumpyf4's Avatar
Diagnose it before removing the alarm or anything else.
Install an ammeter between the negative terminal and the the negative battery post. A normal car should have around 20-40 mA parasitic drain. If your car has more start unplugging stuff (pulling fuses) until the amps drop into range. That's the circuit your having issues with.
If your car has 20-40mA drain, then your battery is bad.
Old Jul 28, 2007 | 05:31 AM
RTW DC2R's Avatar
Default Re: Battery keeps draining (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">A normal car should have around 20-40 mA parasitic drain. If your car has more start unplugging stuff (pulling fuses) until the amps drop into range. That's the circuit your having issues with.
If your car has 20-40mA drain, then your battery is bad.</TD></TR></TABLE>
so normal cars have bad batteries??
Old Jul 28, 2007 | 10:14 AM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Re: Battery keeps draining (RTW DC2R)
i had the same problem with a relatively new battery, took it in, and the battery was just a fault from the factory. got a new one free
Old Jul 28, 2007 | 10:21 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
or just remove the alarm. because historically alarms have never saved R's.</TD></TR></TABLE>
so far from true
What extra items do you have plugged into your car. Does your alarm have a back up battery. How are the kill switches installed in your car. My car will do the same thing if not started in about two weeks, I rather keep the relays active then to give the theif one chance to crack it.
Old Jul 31, 2007 | 04:40 PM
stumpyf4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">
so normal cars have bad batteries??</TD></TR></TABLE>
Let me explain. If your car has 20-40mA draw you have normal draw. If you still can't start it after a week then the battery does not have enough capacity... i.e. bad battery. Could be a starter issue too.
If your car has more than 40mA draw then you have excessive draw, fix the issue with the draw.
Old Jul 31, 2007 | 10:32 PM
i2ishift's Avatar
If your car has more than 40mA draw then you have excessive draw, fix the issue with the draw.</TD></TR></TABLE>
make sure the ignition is off and nothing is on before hooking up the Digital Multimeter (DMM) or Ammeter...not doing so will blow the internal fuse in the DMM or Ammeter
I Like Hondas
20
Oct 18, 2006 01:54 PM
'90crxSI
10
Sep 28, 2006 05:23 PM
Knight1
Aug 24, 2005 10:12 PM
ITR9788
Dec 20, 2004 07:44 PM
sky88
Jul 17, 2004 11:30 AM
