JDM exhaust problems
Old Jul 27, 2007 | 07:41 AM
ComCool's Avatar
Default JDM exhaust problems
Hi...
I just got a JDM 5ZIGEN ProRacer A-Spec exhaust from Japan.
Now the exhaust is too long to fit my 99' Ek4 (b16a2). They tell me that is because the JDM Ek4 has a smaller 2,5 diameter CAT.
Now what CAT do I need to make this exhaust fit. And I need to pass emissions. My engine must be a ODB2 now that it's a 99' model.
Old Jul 27, 2007 | 07:44 AM
pdiggitydogg's Avatar
Without knowing the size of the exhaust... Why not just get a stepped flange for the cat, so it can bolt on?
Old Jul 27, 2007 | 08:04 AM
ComCool's Avatar
My stock cat is way to long, cecause they use a mutch smaller cat i Japan.
Old Jul 27, 2007 | 08:21 AM
my mistake...
Whats "way too long"? Why cant you cut the flange, shorten it, reweld the flange?
I mean, it seems fairly obvious to me (?)
Old Jul 27, 2007 | 08:24 AM
ComCool's Avatar
The exhaust is to long, because the JDM cat is smaller.
Old Jul 27, 2007 | 09:00 AM
electron_si's Avatar
Default Re: (ComCool)
the only thing i would say to fix that would be to get a test pipe (if you dont have emissions i nyour state) and chop the flange and reweld it. Whatever cat you have it would be a PITA to do it on
Old Jul 27, 2007 | 09:02 AM
ComCool's Avatar
It needs to pass emissions, so no test pipe. Just need where to get a cat that fits.
Old Jul 27, 2007 | 09:22 AM
j0nb0y22's Avatar
Japan.
Old Jul 27, 2007 | 09:40 AM
Padawan's Avatar
Darth ModerVader
Default Re: JDM exhaust problems (ComCool)
Well, you have two main options.
The first would be to modify (shorten) the exhaust B-pipe so that it will bolt up to your stock cat.
The second option would be to measure the distance between the exhaust B-pipe flange and the header, and then order a custom cat from somewhere like http://SMS-Products.com.
Old Jul 27, 2007 | 10:06 AM
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Why cant you cut the flange, shorten it, reweld the flange?</TD></TR></TABLE>
shorten the exhaust OR the cat converter...
Old Jul 27, 2007 | 11:54 AM
ComCool's Avatar
I quess the best thing to do is to get a JDM ITR 4-1 header, and a 2,5" cat. Then it's 2,5" all the way true.
ComCool
15
Oct 3, 2007 11:02 AM
mr2kqql
May 21, 2003 09:01 AM
Hukd Up
Apr 2, 2003 05:51 PM
Flux
Nov 13, 2002 12:49 PM
travis
Feb 9, 2002 07:16 PM
