one of the battery cables fell off... car died, will not start now
Old Jun 10, 2002 | 03:49 PM
Mr. Softee's Avatar
Default one of the battery cables fell off... car died, will not start now
i put the cable back on obviously, and tightened it up. car goes like its going to start, but just will not turn over. its like the whirr of the ignition before the car starts, just rolling over and over... not a dead starter click... the vafc suddenly after this was getting no power or something, the screen will not go on. SO i wired it out. the car still does nots tart. i am checking the fuses as we speak
Old Jun 10, 2002 | 03:52 PM
Stock R's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (94goldjungsr)
battery may be dead.
i had that when my battery was almost gone. jump start it.
Old Jun 10, 2002 | 03:56 PM
Looose_R's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (Stock R)
try a new battery, you could have killed yours
Old Jun 10, 2002 | 03:57 PM
Austin's Avatar
If the VAFC was not getting power there is a reason...you may have blown a fuse somehow, start pulling and checking fuses under the hood.
Austin
BTW - was it the +, or the - that came loose?
Old Jun 10, 2002 | 10:37 PM
Mr. Softee's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (Austin)
ttt
Old Jun 10, 2002 | 11:17 PM
Mr. Softee's Avatar
okay, so i just went and chekced the fuses. .. the #24 fuse was shot.. i replaced it twice, and both times when i tried to start the car it blew! anyone have any idea?
Old Jun 11, 2002 | 02:44 AM
MiraiZ's Avatar
if its still blowing then the negative and positive currents are still making contact somewhere ...check under the hood carefully...remember: almost everything metal under the hood acts as a negative ground...make sure the positive cable are not touching anything shouldn't be
Old Jun 11, 2002 | 10:33 AM
Mr. Softee's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (MiraiZ)
i'm going to check it now
Old Jun 11, 2002 | 10:45 AM
JPP's Avatar
JPP
I don't know if this is going to help but if it was the positive cable that came off, there is a chance you blew the fuel pump fuse under the hood (EFI 15 amp fuse) (I don't know if that is the # 24 fuse). When you open the fuse box under the hood, it is the last fuse (deepest in the box) on the passenger side.
Old Jun 11, 2002 | 10:49 AM
Mr. Softee's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (JPP)
all of my under hood fuses look okay
Old Jun 11, 2002 | 11:20 AM
Mr. Softee's Avatar
okay, i looked around and carefully put the terminals back on. put in a new fuse, rechecked the ecu connections and started the car and it still blew the fuse. someone help!
Old Jun 11, 2002 | 12:15 PM
Chubz's Avatar
There is definitly a short. What battery wire came off? CHeck the underhood fuel injection fuse (its 15amp fuse)
Old Jun 11, 2002 | 12:17 PM
Mr. Softee's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (SuperTech)
i did, its fine, car still will not start ;(
Old Jun 11, 2002 | 12:40 PM
MiraiZ's Avatar
what fuse is blowing?
Mr. Softee's Avatar
Old Jun 11, 2002 | 12:49 PM
GettaluvR's Avatar
New User
i dont really suggest you do this by yourself. it's too risky, you could of shock yourself to death. use a little money to save ur life, tow the car to autoshop and let "experince" people do it for you
Old Jun 11, 2002 | 12:54 PM
eh-D's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (GettaluvR)
Shock youself to death?
Old Jun 11, 2002 | 12:55 PM
Mr. Softee's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (eh-D)
LOL i dont know about that, but anyway, im taking it to the dealership.
Old Jun 11, 2002 | 06:34 PM
The Toecutter's Avatar
Check the 100 amp fuse in the box. I stuck a screw driver once trying to tension an alternator and it blew. Nothing would work and battery was fine. do you have a multimeter or something that requires a 12v current? Check the fuses and go from there. Careful, contrary to the previous post 80 ampers of current will kill you several times over.
Old Jun 11, 2002 | 06:57 PM
Austin's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (Velocity)
80 amps at 12v, or 80 amps at 110v?
Old Jun 12, 2002 | 05:08 AM
JPP's Avatar
JPP
80 amps is as dangerous at 12 volts then it is at 110 volts. And even if you have the battery disconnected, there can still be some charged capacitor waiting to fry your ***.
[Modified by JPP, 9:09 AM 6/12/2002]
Old Jun 12, 2002 | 06:37 PM
Mr. Softee's Avatar
well honda won't fix my car. i'm going to tinker with it tomorow.
Old Jun 12, 2002 | 06:41 PM
98itR484's Avatar
What do you mean they wont fix your car?? Did they refuse to help???
Old Jun 12, 2002 | 06:46 PM
EagleR's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (98itR484)
WTF they won't fix it or what? I never heard of a shop refusing to even look...
[Modified by EagleR, 10:47 PM 6/12/2002]
Old Jun 12, 2002 | 06:48 PM
Mr. Softee's Avatar
Default Re: one of the battery cables fell off... car died, will not start now (EagleR)
acura refused to do service on my car
