Si wont start.
I have 2000 si and it will turn over but not start. As far as the relay goes its still good. but when i turn my car on i do not hear the fuel pump pumping. Most likely it will be the pump itself but i was just wondering if theres any possibility it could be anything else? I tried spraying choke cleaner directl into the intake and it wouldnt start either, not even for a few seconds. Any help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flat_tires »</TD></TR><TR><TD CLASS="quote">I tried spraying choke cleaner directl into the intake </TD></TR></TABLE>
LOL do you have spark? Check connections to battery,starter,grounds? If you turn the key on and you dont the hear the pump PRIME, chances are its bad. Check fuses. Is there gas in it? Check all first.
muhaMan
Jul 3, 2007 10:01 PM
