AEM EMS help chaning coil drivers
I recently swapped a fully built d16z6 into my 97 civic. I was having the worst problem trying to get the new engine started running my aem ems. I finally figured out i repinned the distributor plug wrong so i fixed that but still no luck. Finally i swapped back in the stock d16y8 ecu and it started up but ran pig rich (880cc injectors, walbro 255h). I believe when i had the distributor plug pinned wrong i blew the coil driver in my aem 1020 box. I ran this same box before i swapped the new motor in and everything worked fine. So my question is how do i switch to a different coil driver or is it something else?
All help will be greatly appreciated.
Ben
Ben
DaveF
Sep 14, 2008 05:59 PM
