Gas smell?
Old Jul 26, 2007 | 08:24 PM
dwayne1413's Avatar
Default Gas smell?
So tonight. For the second time i get in my car to drive home and the ac is spitting out a gas smell.
Recap of what happened before: I drove for about 30 minutes to clearwater. let it sit for about an hour while i was going my thing and came back. its only done this one other time. it didnt start spitting out the gas smell until after i got on it alittle bit to get around this guy in a round-about.
any suggestions?
1997 EX f22b1 only mod -> CAI
Old Jul 26, 2007 | 08:31 PM
95-Accord-EX's Avatar
u might, big might, have a little leak in your exhaust. I had the same thing happen awhile back...and i found a 3in crack in my downpipe. yeah so just check ot
Old Jul 26, 2007 | 08:35 PM
dwayne1413's Avatar
Default Re: (95-Accord-EX)
hmmm. car is lowered.... could be a possibility. where would i look. directly until the front? im not really sure how the ac works and where they would even meet.
Old Jul 27, 2007 | 10:52 AM
dwayne1413's Avatar
Default Re: (dwayne1413)
bump? anyone?
Old Jul 27, 2007 | 11:33 AM
BLKFLSH's Avatar
Not sure if this is even possible, but the injectors could be leaking a little, and the vapors are being sucked in by the air conditioner intake at the bottom of the windshield. Just an idea. Good luck finding the source.
Old Jul 27, 2007 | 01:18 PM
dwayne1413's Avatar
Default Re: Gas smell? (dwayne1413)
bump anyone else?
Old Jul 27, 2007 | 01:34 PM
ujhonda's Avatar
I think you can spry some soapy water on every joint/connector you suspect to find the leak...but get more help from pros...
if you smell gas - you must fix this - before something serious happen.
Old Jul 27, 2007 | 01:55 PM
dwayne1413's Avatar
Default Re: Gas smell? (ujhonda)
but its not all the time. its actually the second time in maybe weeks. once i turned the ac off for 4-5 minutes the smell went away.
Old Jul 27, 2007 | 03:04 PM
BLKFLSH's Avatar
If it was a fuel line I think you would smell the gas all the time. When you "got on it" like you said it could have put more pressure on the injector o-rings, and that's when it leaked a little. When the fuel injectors leak, the gas will evaporate quickly on the hot intake, so the smell doesn't last long. It's also pretty close to where the A/C intake is. Get someone to sit in the car and rev it up a little, and see if you can spot something leaking. Good luck.
Old Jul 27, 2007 | 03:34 PM
dwayne1413's Avatar
Default Re: Gas smell? (BLKFLSH)
yeah i guess i can try that. if it were inhector o-rings, how hard and how much would it be to replace them?
Old Jul 27, 2007 | 04:56 PM
BLKFLSH's Avatar
The o-rings and seals would not cost much. The fuel rail has to be removed to get them out. It's not a hard job really. Make sure this is where the leak is before changing things. Good luck.
2fast4u831
Welding / Fabrication
17
Nov 14, 2013 09:48 PM
TrickHonda98
May 4, 2010 01:01 PM
da_33
Oct 26, 2006 08:45 PM
Paste
Sep 6, 2002 10:09 PM
shawnhayes
14
Jul 16, 2002 03:38 PM
