vss trouble
Old Jul 26, 2007 | 07:54 PM
vsmhatched's Avatar
Default vss trouble
first off my car is a 96 hatch with a b18c1 bottom with itr pistons and rods, b16 head with R cams, boomslang ecu harness to PR3 ecu. OK, my car is running like its in safe mode, it has slow rev's and is really slow, only rev's to 7500 rpm, but takes forever to get there. Its really sluggish. I have only 2 codes, 41 (o2 sensor) and 23 (knock sensor). I know these codes do not make my car go into safe mode or limp mode, it just makes in not run as good as it should. But the thing is my speedo is not working, it does NOT throw code 17 even after driving the car around. Since my speedo quit working, my car started acting up like this. So, I've tried replacing the gauge cluster just to see if it had a effect on it cause i had a extra one laying around. Then I tried to replace the speed sensor with a d-series one, but still no good. All fuses are good too. Also, the speed sensor worked in the car the trans came from just 2 days ago, so why would it not work as soon as i swapped it in my car and not throw a code. Any idea's or should i just pick up a b-series one even tho this one could still possible be good cause its not throwing a code for it.
Old Jul 26, 2007 | 08:53 PM
mtny's Avatar
Default Re: vss trouble (GreyDel)
Bump cuz I suck and I don't know anything.
Old Jul 26, 2007 | 09:08 PM
Capt. Jimbo McSubipants's Avatar
Default Re: vss trouble (mtny)
oh i thought you said it was throwing a code for VSS?
ok first of all...now that i remember....
92-93 were cable driven speedo's if i remember correctly..
could be the reason why your car is running like poo
Old Jul 26, 2007 | 09:09 PM
Default Re: vss trouble (CW-R hatchback)
you really need a tuned ecu man...that old as fug pr3 blows...
Old Jul 26, 2007 | 09:17 PM
vsmhatched's Avatar
yeah,early today it did throw the code....now it doesnt at all. Also, the pr3 ecu worked in a eg coupe and the speed sensor worked. BTW my trans is a 99 b16. I need to get another ecu for sure, but i want to get everything working first
Old Jul 26, 2007 | 09:18 PM
reasearched it...
nvm..i was correct about the cable driven speedo but apparently it has nothing to do with the cable...the cluster itself has wiring in it to tell the ecu what and how fast its going...
and your right on that its B10...its suppose to be an orange or brown wire going to it...
Old Jul 26, 2007 | 09:26 PM
vsmhatched's Avatar
[QUOTE=CW-R hatchback .its suppose to be an orange or brown wire going to it...[/QUOTE]
I thought it was suppose to be blue with a white strip
Old Jul 26, 2007 | 09:31 PM
that would be the one coming from the dizzy to the cluster for the tach...
if i remember correctly...
apparently andy its a 50/50 shot it could be your 02 sensor causing this damage as well..
i did a search and people say sometimes it goes into safe mode...sometimes people can still beat the living day lights out of there cars...
Old Jul 26, 2007 | 09:34 PM
i'm off to bed but i think tommarow you should check the following
check timing on the belt side...
make sure all wiring is the best it can be
check grounds....we all know how grounds are....it could be this....
you don't have to pull everything apart to check the timing on the belt side..
just look at the pulley and match it up to the mark on the timing cover make sure your at TDC first...
then look at the cams and see if there golden...if your convinced the timing is A1 then move on....its proboly something retarded....
Old Jul 26, 2007 | 09:55 PM
vsmhatched's Avatar
thanks for the tips JIm, i'll give you a call tomorrow and tell you whats going on
Old Jul 27, 2007 | 12:48 AM
ZaCh AttaCk's Avatar
if its acting sluggish and wont rev past 7500
my bet would be timing off a tooth somewhere
now the speedo thing i have no idea but i got a b series VSS you could use try or whatever
let me sleep on it and ill think of something lol
put a 02 sensor in it see if it does better first off
Old Jul 27, 2007 | 08:14 AM
vsmhatched's Avatar
Default Re: (ZaCH AttaCK)
Zach...text or call me today so i can try that speed sensor
Old Jul 27, 2007 | 11:12 AM
ekay. jay's Avatar
Default Re: (GreyDel)
sounds like cam timing to me. and have you tried setting the ignition timing at all? is it running rich or lean? hows the throttle response?
Old Jul 27, 2007 | 11:54 AM
vsmhatched's Avatar
Default Re: (ekay. jay)
car is way rich...put new plugs in and they're solid black now...lol, im gonna gout and put in a new o2 and check my wiring for the knock sensor to get rid of those check engine lights. My timing gun will be here late tonight, so i'll have a chance to check it out . Also....Zach, im gonn try that speed sensor off you. Throttle response is kinda poor, it not revving correctly at all
Old Jul 27, 2007 | 11:57 AM
text for you!
Old Jul 27, 2007 | 12:01 PM
ekay. jay's Avatar
to you have the TPS and MAP sensor plugs crossed? that would be the first thing id check. it would cause your car to run extremly rich.
what ever the problem is, it has nothing to do with the knock sensor or the vss.
Old Jul 27, 2007 | 01:44 PM
RaceCarRyne's Avatar
id check your oil level. and put some royal purple in it.. will fix it all.. haha jk... ecu is prolly the problem.. i remeber one time i put a p61 ecu on my gsr and it did the same thing.. then i got the p72 and it ran perfect.. dont know how to explain it but that is what happend
Old Jul 27, 2007 | 01:50 PM
vsmhatched's Avatar
Default Re: (DC2jdmIntegra)
tps and map are correct, also i just changed the oil with royal purple before any of this started Knock and 02 cel's are fixed....still no speedo and runs like ****. I'll just have to wait until i get my timing gun back tonight and pick up the speedo from Zach
Old Jul 27, 2007 | 01:52 PM
vsmhatched's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZaCH AttaCK &raquo;</TD></TR><TR><TD CLASS="quote">text for you! </TD></TR></TABLE>
text you back...whenever is good for you tonight, i'll meet up with you. O-reilly's in hermitage again?
Old Jul 27, 2007 | 02:07 PM
ekay. jay's Avatar
what obd are you, i wouldnt mind letting you use my chipped p28 to see if that helps. p28 is obd-1, i have a obd-2a to obd-1 conv harness.
Old Jul 27, 2007 | 02:13 PM
vsmhatched's Avatar
i got a boomslang obd2a to obd1 harness....i tried using my stock y8 obd2a ecu to see if anything happens...and it was still the same. If i find out that the timing is perfect and i get a that speedo from Zach and it still doesnt fix anything, i'll want to try out that ecu of yours for sure
Old Jul 27, 2007 | 02:21 PM
ekay. jay's Avatar
yea my ecu has a dyno tunned basemap of my ls/vtec when it was stock so it should work pretty good on your motor.
Old Jul 27, 2007 | 02:25 PM
vsmhatched's Avatar
yea, i'll let ya know later on tonight and maybe i could borrow it if i need to, thanks jay
Old Jul 27, 2007 | 02:29 PM
ekay. jay's Avatar
Old Jul 27, 2007 | 04:09 PM
ej12007's Avatar
CAN ANYONE HELP ME OUT... i want to sell me car but im new on honda-tech and they wont allow me.... who can help me out&gt;?
